Community
cancel
Showing results for
Search instead for
Did you mean:
BHarr8
New Contributor III
NUC8i7HVK cannot create RAID with 2 800P
I made another thread in general NUC before I realized there was a specific section for the NUC8i7HVK.
The issue I am having is that there seems to be a bug in the visual BIOS (yes I updated to V40) that prevents 2 800P SSDs from remapping to RST.
When you attempt to this is what happens:
BHarr8
New Contributor III
When in RST, this is how the 2 drives are listed.
The top pic is RAID on + remapping off.
The bottom pic is RAID on + remapping on.
Notice how with remapping off RST sees both controllers correctly but with remapping on both drives end up on the same controller and only one drive gets assigned a port?
I have a strong suspicion that this is due to the 2X lanes that these drives run on. I believe that the first 4X lane mistakenly gets split up to cover both 2X drives making RAID impossible.
Community Manager
Hello, nosirrahx. Thank you very much for contacting the Intel Communities Team. I will be more than happy to assist you.
I can see that you are being assisted by Leonardo on the thread: /thread/125927 https://communities.intel.com/thread/125927
Please keep monitoring that thread, we will keep updating it.
Antony S.
JLi86
How does it work now? It's a hardware problem or some kind software bug? I just bought it for a few days,and now I have the same issue. Do I need to return this one and buy a new one?
