Shortly after a BIOS update that removed legacy boot, my ethernet adapters disappeared from the device tree. The driver install does not detect them, they do not show up as other device, and I do not get a link light when I plug a cable into either jack (which is connected elsewhere). They are enabled in the BIOS. I tried clearing the CMOS battery and also resetting the BIOS by removing the jumper. When I remove the jumper and boot, during the 'reset' I get activity lights back on the ports for a short moment, then the BIOS is reset and they turn off. Even while I am in the BIOS I do not get activity lights, and the ethernet adapters are clearly checked as on in the bios. Any ideas?
1. Enter BIOS (press F2 while booting). Press F9 (confirmed by "Y") to set BIOS to default settings. Now press F10 (followed by "Y") to save the settings and exit to Windows.
2. In the search box on the taskbar, type Network troubleshooter, and then select Identify and repair network problems from the list of results. Follow the steps in the troubleshooter and see if that fixes the problem.
3. If that doesn't fix your connection problem, try these things: https://support.microsoft.com/en-us/help/10741/windows-fix-network-connection-issues https://support.microsoft.com/en-us/help/10741/windows-fix-network-connection-issues
Leon
Hi Leon - I should have mentioned I'm an engineer on the Windows OS - I've tried all three. The devices aren't being enumerated by the OS.
Here's some info about the PCI bus:
I can't see, for example, 8086:15d5 which would be the I219-LM. I think it might be an issue under the PCH?
lkd> !pcitree
Bus 0x0 (FDO Ext ffffaa0af958f630)
(d=0, f=0) 80865910 devext 0xffffaa0af8485880 devstack 0xffffaa0af8485730 0600 Bridge/HOST to PCI
(d=1, f=0) 80861901 devext 0xffffaa0af83d5890 devstack 0xffffaa0af83d5740 0604 Bridge/PCI to PCI
Bus 0x1 (FDO Ext ffffaa0af8490190)
(d=0, f=0) 1002694c devext 0xffffaa0af96461b0 devstack 0xffffaa0af9646060 0300 Display Controller/VGA
(d=0, f=1) 1002ab08 devext 0xffffaa0af96451b0 devstack 0xffffaa0af9645060 0403 Multimedia Device/Unknown Sub Class
(d=1, f=1) 80861905 devext 0xffffaa0af84841b0 devstack 0xffffaa0af8484060 0604 Bridge/PCI to PCI
Bus 0x2 (FDO Ext ffffaa0af95ed190)
(d=0, f=0) 1b212142 devext 0xffffaa0af95841b0 devstack 0xffffaa0af9584060 0c03 Serial Bus Controller/USB
(d=1, f=2) 80861909 devext 0xffffaa0af95b81b0 devstack 0xffffaa0af95b8060 0604 Bridge/PCI to PCI
Bus 0x3 (FDO Ext ffffaa0af95ef190)
(d=0, f=0) 12178621 devext 0xffffaa0af95c81b0 devstack 0xffffaa0af95c8060 0805 Base System Device/Unknown Sub Class
(d=2, f=0) 8086591b devext 0xffffaa0af95d01b0 devstack 0xffffaa0af95d0060 0380 Display Controller/'Other'
(d=8, f=0) 80861911 devext 0xffffaa0af964d1b0 devstack 0xffffaa0af964d060 0880 Base System Device/'Other' base system device
(d=14, f=0) 8086a12f devext 0xffffaa0af96501b0 devstack 0xffffaa0af9650060 0c03 Serial Bus Controller/USB
(d=14, f=2) 8086a131 devext 0xffffaa0af96511b0 devstack 0xffffaa0af9651060 1180 Unknown Base Class/Unknown Sub Class
(d=15, f=0) 8086a160 devext 0xffffaa0af96521b0 devstack 0xffffaa0af9652060 1180 Unknown Base Class/Unknown Sub Class
(d=15, f=1) 8086a161 devext 0xffffaa0af96531b0 devstack 0xffffaa0af9653060 1180 Unknown Base Class/Unknown Sub Class
(d=15, f=2) 8086a162 devext 0xffffaa0af96541b0 devstack 0xffffaa0af9654060 1180 Unknown Base Class/Unknown Sub Class
(d=16, f=0) 8086a13a devext 0xffffaa0af96551b0 devstack 0xffffaa0af9655060 0780 Simple Serial Communications Controller/'Other'
(d=1c, f=0) 8086a110 devext 0xffffaa0af96561b0 devstack 0xffffaa0af9656060 0604 Bridge/PCI to PCI
Bus 0x4 (FDO Ext ffffaa0af74d5190)
No devices have been enumerated on this bus.
(d=1c, f=1) 8086a111 devext 0xffffaa0af96571b0 devstack 0xffffaa0af9657060 0604 Bridge/PCI to PCI
Bus 0x5 (FDO Ext ffffaa0af75c3c00)
(d=1c, f=2) 8086a112 devext 0xffffaa0af96581b0 devstack 0xffffaa0af9658060 0604 Bridge/PCI to PCI
Bus 0x6 (FDO Ext ffffaa0af9590c00)
(d=0, f=0) 808624fd devext 0xffffaa0af95c61b0 devstack 0xffffaa0af95c6060 0280 Network Controller/'Other'
(d=1c, f=4) 8086a114 devext 0xffffaa0af96591b0 devstack 0xffffaa0af9659060 0604 Bridge/PCI to PCI
Bus 0x7 (FDO Ext ffffaa0af95c3190)
(d=1d, f=0) 8086a118 devext 0xffffaa0af965a1b0 devstack 0xffffaa0af965a060 0604 Bridge/PCI to PCI
Bus 0x72 (FDO Ext ffffaa0af95c3750)
(d=1d, f=4) 8086a11c devext 0xffffaa0af965b1b0 devstack 0xffffaa0af965b060 0604 Bridge/PCI to PCI
Bus 0x73 (FDO Ext ffffaa0af95afc00)
(d=0, f=0) 144da808 devext 0xffffaa0af95c21b0 devstack 0xffffaa0af95c2060 0108 Mass Storage Controller/Unknown Sub Class
(d=1e, f=0) 8086a127 devext 0xffffaa0af965c1b0 devstack 0xffffaa0af965c060 1180 Unknown Base Class/Unknown Sub Class
(d=1f, f=0) 8086a152 devext 0xffffaa0af95ad1b0 devstack 0xffffaa0af95ad060 0601 Bridge/PCI to ISA
(d=1f, f=2) 8086a121 devext 0xffffaa0af95ac1b0 devstack 0xffffaa0af95ac060 0580 Memory Controller/'Other'
(d=1f, f=3) 8086a171 devext 0xffffaa0af95a21b0 devstack 0xffffaa0af95a2060 0403 Multimedia Device/Unknown Sub Class
(d=1f, f=4) 8086a123 devext 0xffffaa0af95911b0 devstack 0xffffaa0af9591060 0c05 Serial Bus Controller/Unknown Sub Class
Total PCI Root busses processed = 1
Total PCI Segments processed = 1
lkd> !pci 603 ffff ff
Scanning the following PCI segments: 0
PCI Segment 0 Bus 0
00:0 8086:5910.05 Cmd[0006:.mb...] Sts[0090:c....] Intel Host Bridge SubID:8086:2073
cf8:80000000 IntPin:0 IntLine:0 Rom:0 cis:0 cap:e0
01:0 8086:1901.05 Cmd[0407:imb...] Sts[0010:c....] Intel PCI-PCI Bridge 0->0x1-0x1
cf8:80000800 IntPin:1 IntLine:ff Rom:0 cap:88 2sts:2000 BCtrl:18 VGA
IO:e000-efff Mem:db500000-dbefffff PMem:90000000-a01fffff
01:1 8086:1905.05 Cmd[0407:imb...] Sts[0010:c....] Intel PCI-PCI Bridge 0->0x2-0x2
cf8:80000900 IntPin:1 IntLine:ff Rom:0 cap:88 2sts:2000 BCtrl:4 ISA
IO:d000-dfff Mem:dab00000-db4fffff PMem:fff00000-fffff
01:2 8086:1909.05 Cmd[0407:imb...] Sts[0010:c....] Intel PCI-PCI Bridge 0->0x3-0x3
cf8:80000a00 IntPin:1 IntLine:ff Rom:0 cap:88 2sts:2000 BCtrl:4 ISA
IO:c000-cfff Mem:da100000-daafffff PMem:fff00000-fffff
02:0 8086:591b.04 Cmd[0400:......] Sts[0010:c....] Intel Other Display Controller SubID:8086:2073
cf8:80001000 IntPin:1 IntLine:0 Rom:0 cis:0 cap:40
MEM[0]:fe000004 IO[1]:2f MPF[2]:a000000c IO[3]:2f IO[4]:fec1
08:0 8086:1911.00 Cmd[0000:......] Sts[0010:c....] Intel Other System Peripheral SubID:8086:2073
cf8:80004000 IntPin:1 IntLine:ff Rom:0 cis:0 cap:90
MEM[0]:ff02b004 IO[1]:2f
14:0 8086:a12f.31 Cmd[0406:.mb...] Sts[0290:c....] Intel Class:c:3:30 SubID:8086:2073
cf8:8000a000 IntPin:1 IntLine:0 Rom:0 cis:0 cap:70
MEM[0]:ff010004 IO[1]:2f
14:2 8086:a131.31 Cmd[0002:.m....] Sts[0010:c....] Intel Other Signal Processing Controller SubID:8086:2073
cf8:8000a200 IntPin:3 IntLine:ff Rom:0 cis:0 cap:50
MEM[0]:ff02a004 IO[1]:2f
15:0 8086:a160.31 Cmd[0400:......] Sts[0010:c....] Intel Other Signal Processing Controller SubID:8086:2073
cf8:8000a800 IntPin:1 IntLine:10 Rom:0 cis:0 cap:80
MEM[0]:fffea004 IO[1]:2f
15:1 8086:a161.31 Cmd[0400:......] Sts[0010:c....] Intel Other Signal Processing Controller SubID:8086:2073
cf8:8000a900 IntPin:2 IntLine:11 Rom:0 cis:0 cap:80
MEM[0]:fffe9004 IO[1]:2f
15:2 8086:a162.31 Cmd[0400:......] Sts[0010:c....] Intel Other Signal Processing Controller SubID:8086:2073
cf8:8000aa00 IntPin:3 IntLine:12 Rom:0 cis:0 cap:80
MEM[0]:fffe8004 IO[1]:2f
16:0 8086:a13a.31 Cmd[0406:.mb...] Sts[0010:c....] Intel Other Communications Controller SubID:8086:2073
cf8:8000b000 IntPin:1 IntLine:0 Rom:0 cis:0 cap:50
MEM[0]:fffe7004 IO[1]:2f
1c:0 8086:a110.f1 Cmd[0404:..b...] Sts[001...
Hi ianhan ,
Probably in Windows you are expert more than I'm. I've have long experience in RT S/W. So, I understand that you know how to fix network problems in Windows. I've some other suggestion to try:
1. Enter Bios Advanced>Devices>Onboard Devices and remove the check mark (disable) LAN.
Press F10 to save the setting and reboot the NUC to Windows.
Shut down the NUC.
Switch the NUC ON and enter Bios Advanced>Devices>Onboard Devices and check (enable) LAN.
2. I assume that you have updated Bios by pressing F7 key. If I'm right, please try to update Bios using Bios recovery method - with Security Jumper removed: https://www.intel.com/content/www/us/en/support/articles/000005532/mini-pcs.html BIOS Recovery Update Instructions for Intel® NUC
3. If the above suggestion will not help please download Intel System Support Utility: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Download Intel® System Support Utility for Windows* , Run it, and save the generated by this tool report. Attach this report (press Attach in the right bottom corner) to your post. Intel support agent will always ask for such report. This will save your time for getting support from Intel.
Leon
Hi Leon,
Tried:
- Update from within bios UI
- Running BIOS update .efi from UEFI shell
- Removing jumper and updating using text UI
- Using the auto-flash from USB method
Unfortunately no luck. I also tried disabling nic, shutdown, enable nic, and boot to Windows. No luck. I kind of wonder if I messed up much earlier somehow.
EFI shell can't see the devices matching the nics vid/pid via pci/device lists.
Report attached.
Thanks for your help Leon!
I was looking into the report you sent. I see that you have active an TAP-Windows Adapter V9. I think that after disabling/removing this adapter your network adapter should work again.
Leon
Hey Leon - I can't find that in the adapter list or the log - can you check the log again, or paste the part that has it?
Thanks again
-Ian
Hi Ian,
Sorry for misleading you. I was looking in somebody else report. saved on my computer. You are right, in your report there is no network adapter (have to be two adapters). The best way to see this report is not in editor, rather open the text file in the SSU (the Intel tool). You shall use the Detailed View. You can download such report send by other NUC8i7HVK user and compare to yours (see the Networking section).
In my opinion, the network adapter in your NUC failed and you shall replace your NUC. You can do this in the place of purchase or issue request fir RMA to Intel: https://supporttickets.intel.com/warrantyinfo?lang=en-US Warranty Information
https://www.intel.com/content/www/us/en/support/articles/000005679/mini-pcs.html Warranty Information for Intel® NUC Products
Any way, today may be you will have some other advice from Intel Support Agent.
Leon
Hello ianhan,
Thank you for joining our Intel ® Community.
I have sent you a private message in order to discuss some personal information regarding your account and your issue.
Please take a look at your inbox.
I hope to hear from you soon.
Diego S.
