Hi everyone, I just ordered the NUC and am very excited to get this thing setup. It still hasn't come in yet, but I am preemptively downloading required drivers for the nuc. I am preforming a clean windows w10 install and manually installing software as needed.
I guess I just wanted to know is there anything I should be aware of when setting this thing up for the first time? just to make it as painless as possible. I built my own pc, but I am not sure if things have changed much since I last tinkered with them years ago. Are there install orders for drivers or hardware? does each driver require a restart or can they be bulk installed? Never updated a bios but how difficult is it with the nuc? sorry if this has all been asked before, I am just a little nervous.
thanks in advance, hope everyone is having a wonderful day!
kind regards, sam.
Hello MrHadesCanyon,
I understand that you are getting started with our Intel® NUC8i7HVK, it will be a pleasure to assist you.
Purchasing a new unit might seem to be a little overwhelming, however everything you need to know is just one click away from the following link:
https://www.intel.com/content/www/us/en/support/articles/000028146/mini-pcs/intel-nuc-kits.html https://www.intel.com/content/www/us/en/support/articles/000028146/mini-pcs/intel-nuc-kits.html
The link above will provide you with all the practical information regarding your unit.
Some of the information found there will include:
-User Guide for Beginners that includes details on how to assemble the hardware inside the unit
-Tested RAM modules list.
-Link to install the latest Drivers and BIOS
-How to Update the BIOS
In addition, the order for the driver installation must be as follows:
-First Intel graphic Drivers
-Reboot your machine
-Then Radeon* Drivers (found on the link above)
I hope this helps.
Best regards.
Diego S.
I hope this helps.
Best regards.
Diego S.
Thank you for the helpful information.
I asked some similar questions before I got mine-
It seems that order is only important with the video drivers as noted above.
I installed the chooser driver first, then the video drivers, then just went down the list of drivers and software in the Intel driver link.
I rebooted when it said required, but basically after the video, and then after installing 2-3 others at a time. My original BIOS was 29, and I upgraded that to 40 after all of the drivers. (There is a BIOS ver 44 now).
One thing I would recommend- if you got a little paper advertising free software, check it out-of-town you can get a free copy of Laplink PC mover to help transfer settings and applications from your old computer. See my other post about this. It will save you about $70 since Windows no longer includes this utility.
Good luck and have fun! If you need help, past here. There are a lot of very helpful folks here!
