Good morning,
I'm not able to use my desktop microphone with the NUC8i7HVK.
This is the microphone https://translate.google.it/translate?hl=it&sl=it&tl=en&u=https%3A%2F%2Fwww.amazon.it%2Fgp%2Fproduct%2FB00CXKQ5U4%2F
The microphone is already tested and working with skype in my desktop computer, so it should work also with the NUC8i7HVK.
I already have done what is suggested here
https://www.intel.com/content/www/us/en/support/articles/000032598/mini-pcs.html
My driver is Realtek High Definition Audio Driver for Windows 10 64-bit_6.0.1.8454 (2018.29.05)
I already have tryed the front and rear panel jack and I'm not able to use the microphone.
Here you can find some screenshots
Thank You
Hello Serafino,
Thank you for posting on this Intel Community.
Since you have installed the latest Realtek* High Definition Audio Driver for your unit, please follow these recommendations and let us know if the problem persists:
1. Go to Settings > Sound Settings and check your input devices.
2. Under Related Settings, go to Sound Control Panel and set your Microphone as Default Recording Device.
- Recording devices > Right-click your microphone, and click on "Set as default device"
3. You can also go to Microphone Privacy Settings
- Head over to the Microphone section and check if the Microphone is "On".
4. Check if microphone is muted
- Go to Recording devices (Sound Control Panel)
- Right-click your microphone and go to Properties
- Go to the Levels tab and increase the level of your microphone
Wanner G.
Under Contract to Intel Corporation
Hello Serafino,
If you need further assistance, please let us know.
Wanner G.
Hello Serafino,
If you need further assistance, please contact us back.
Wanner G.
