everytime I start Fortnite, the game ask me to update the Vega M GH graphics driver.
Installed is this https://downloadcenter.intel.com/download/27895/NUCs-Radeon-Graphics-Driver-for-Intel-NUC-Kit-NUC8i7... driver. So the newest..
I'm still able to play, so just wondering what this is about.
- Tags:
- Drivers
Hello fabih1,
I understand that you are currently experiencing an issue with graphics update since it shows as if there was an update but you have the newest.
I would like to actually try to install a newer version that was released no long ago. This is to check and see if the notification stops popping up like that, please refer to the link below, download the driver and reboot the system to check:
https://downloadcenter.intel.com/download/27881/Graphics-Radeon-RX-Vega-M-Graphics?product=136866 https://downloadcenter.intel.com/download/27881/Graphics-Radeon-RX-Vega-M-Graphics?product=136866
Let me know the outcome please.
David V
Now it's 18.6.1 instead of 18.5.1 (screenshot attached)
Why is this driver not in the NUC8i7HVK download section?
Fabi
Hello fabih1,
Thank you for your response.
The reason why the driver is not listed under the NUC section is because this is a generic driver for the Integrated Graphics you have which has not yet been validated with the NUC; however, there is no problem since it is for the adapter. Now, I was checking online and I was able to find the following:
https://www.amd.com/en/support/kb/release-notes/rn-rad-win-18-7-1 https://www.amd.com/en/support/kb/release-notes/rn-rad-win-18-7-1
* Please be aware that the content on that site is not controlled by Intel*. This information is offered for your convenience and should not be viewed as an endorsement by Intel* for the merchants or services offered there. *
That link takes you to the AMD* website where you can download the latest version of Adrenalin software. I would like you to go ahead and download the version for your system and then try again to see if the error persists, there should not be any problem whatsoever with the process. If it gives you any error then please let me know.
David V
error 182.
I'm back at the Intel NUC driver.
Fortnite is running well on this driver, so I stay with that driver and just ignore the popup.
Fabi
Hello fabih1,
I understand that you are back to the previous version. In this case, what I can recommend you to do is to keep checking our download center for an updated version validated by Intel.
I apologize for any inconvenience.
David V
