Intel® NUCs
Assistance in Intel® NUC products
13298 Discussions
NUC8i7HVK power on
lkomem
I have NUC8i7HVK that won't power on.
After a long vacaction that NUC was off and disconnected from power, it won't power on.
I tried to disconnect the CMOS battary for 15 minutes and it didn't help.
Any other ideas ?
lkomem
I will put in to a lab. maybe some issue in power delivery on the board
LeonWaksman
Did you checked the voltage on Power Supply plug?
Can you you test with other Power Supply?
On the boar lower side, there is a Standby LED/ It should be illuminated. You may see the LED light through the vent holes in dark room.
Leon
lkomem
I checked the power supply (with volt meter) and also tried with another power supply.
I didn't see a Standby LED (maybe not dark enough)
LeonWaksman
You should be able to see the light from this LED while looking trough the front vent holes. If you don't see any light when the Power Adapter plug is connected (after you verify that there is no problem with the Power Adapter), means that there is a failure on the board in the power circuitry.
You may check here if there is Warranty Coverage for your NUC.
Leon
lkomem
