Intel® NUCs
12341 Discussions
NUC8i7HVK4 Display issues
MLill2
I have just setup a NUC8i7HVK4 with Windows 10 1903 and have installed all the updates that I can find for the NUC. I have the NUC connected to three SAMSUNG QM49H professional Displays. The displays will come on and display for a second and then go off when using the mini dvi on the NUC.
When using HDMI its fine.
Any ideas?
AlHill
I keep seeing users reporting problems with Samsung displays.
Doc
n_scott_pearson
Super User Retired Employee
How were you connecting the monitors when using mDP connectors?
I have been using the Rear HDMI and the two USB-C (with DVI dongles). I found that my mDP adapters (and I have four different kinds that I tried) do not stay seated in the mDP connectors. Wiggling will get them working, but the second I let go of the cable they snow back up or blank out.
I was blaming this on having an Engineering Sample, but maybe it is a consistent flaw.
LeonWaksman
I have not observed any problems with the DP connectors on my NUC. I'm using those connectors in my setup.
Are you using high speed DP cable? This is an example: https://www.amazon.com/ivanky-DisplayPort-Braided-Display-Compatible/dp/B078HVDMW2/ref=sr_1_3?crid=H...
Leon
MLill2
Thanks for your input people.
Ok, a small bit of progress. I have added minidp to hdmi converters at the NUC end. This has enabled the displays to stay up at least. The software I am trying to display is HIK Central (CCTV Software) There is a setting in the software where I can switch from CPU to GPU, doing this causes a DLL error in the HIK Central software on the higher resolution cameras (4 mega pixel and above). Using CPU runs the CPU to nearly 100%. (I bought the NUC's so I could use the GPU's.) Could it be that the latest AMD Raedon drivers for the NUC arent playing nicely with the HIKCentral Software. Dll Error reads Live View failed.Errorcode: Control Client, Playctrl.dll [16]. I'll be posting this on the HIK Vision forum.
Alberto_R_Intel
MLill2, I just wanted to check if a solution was provided on the HIK Vision forum and if you need further assistance on this matter?
Alberto R.
A Contingent Worker at Intel
MLill2
Unfortunately, it would appear that the INTEL NUC just does not have enough GPU processing power to do what I need it to do. :( So I am going to have to get a full sized box with a 2080 type video card.
Alberto_R_Intel
MLill2, Thank you very much for letting us know those updates.
We are sorry to hear that the Intel® NUC did not work for the purpose you need it to, hopefully, the full-sized box will work as you expected.
Any other inquiry, do not hesitate to contact us again.
Alberto R.
