Intel® NUCs
12323 Discussions
NUC8u7HNK - possible to hook up traditional SATA hdd?
JMand3
I see a traditional SATA power connector inside, but no data. Is there anyway to hook up a traditional SATA drive to this? Even temporarily? I need to use my NUC to do something to a 2.5" SATA HDD
Cant use sata to USB cable as i need it to be bootable/show up in boot screen
LeonWaksman
If you can boot from bootable USB stick (and you can see such USB in the Boot Menu), are you sure that it will not be possible from you drive installed in SATA to USB adapter?
Leon
JMand3
I am trying to make this WD HDD compatible to use with my 360. the program to do that supposedly wont recognize drives connected that way. I dont get why the sata power header O.o
n_scott_pearson
Super User Retired Employee
Each of the two M.2 sockets in this NUC includes support for a SATA lane. There are adapters that you can get that will expose this SATA lane using a standard SATA Data header. Here is such an adapter: https://www.amazon.com/NGFF-SATA-Converter-Adapter-Cable/dp/B0828TFFH1 (US$10).
