Intel® NUCs
Assistance in Intel® NUC products
13313 Discussions
NUC8v5PNK firmware and acpidump
harwang
I installed Ubuntu 20.04.2.0 LTS on NUC8v5PNK and installed acpica-tools to play with acpi tables. Basically I just follow the steps here: https://www.kernel.org/doc/html/latest/admin-guide/acpi/initrd_table_override.html
But I see errors like "could resolve symbol" in dsdt.dsl and if I do iasl -sa dsdt.dsl, I get compile errors.
I've tried all versions of acpica-tools for ubuntu listed here: https://www.ubuntuupdates.org/pm/acpica-tools. But none of them can create dsdt.aml.
Do you know where can I get the right version of acpica-tools for this beauty?
Harry
Alberto_R_Intel
harwang, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance to your inquiry about "the right version of acpica-tools", we will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
Alberto_R_Intel
Hello harwang, I just received an update on this matter.
After reviewing the case, we confirm, as you mentioned previously, that the software that you are using was downloaded from:
This means that you are getting those apps from a 3rd party source, so what we recommend is to get in contact directly with the Linux distros for further assistance on this matter:
https://www.intel.com/content/www/us/en/support/topics/linux-osv.html
Or you can always visit Ubuntu forums as well for further support on this subject:
https://ubuntuforums.org/
https://ubuntu.com/support/community-support
Albert R.
harwang
Hi Albert,
Thank you for the reply. I forgot to mention in my previous post that the reason I tried all versions of acpica-tools from the link is because the official ubuntu version I installed from apt install is also not working.
I think the best way to get the answer for this question is to ask the vender of the firmware writer, therefore asking Intel should be much better than asking Ubuntu.
Harry
Alberto_R_Intel
Hi harwang, You are very welcome, thank you very much for your response.
Sure, I will double-check again on this case, and as soon as I get more details I will post all the updates on this thread.
Albert R.
Ronny_G_Intel
Community Manager
Hi @harwang
The NUC8v5PNK has been officially validated to work with Ubuntu 18.04 LTS*, refer to the following URL for further reference: https://www.intel.com/content/www/us/en/support/articles/000005628/intel-nuc.html so in a previous post you mentioned that the reason why you are using the acpica-tools from https://www.ubuntuupdates.org/pm/acpica-tools is that the official Operating System deployment is not working. We are very limited to support the acpica-tools, we dont know these tools, they are opened source and I would better recommend that you check with the developer of these tools but we can help you troubleshoot the issue with Ubuntu 18.04 LTS*.
Please provide us with a description of the issue, any pertinent log file or screenshot, and the Intel SSU log file https://www.intel.com/content/www/us/en/download/18895/26735/intel-system-support-utility-for-the-linux-operating-system.html
Ronny G
harwang
Hi Ronny,
Thank you for your reply. Unfortunately I just pass the device to my colleague for other purpose, so I cannot install Ubuntu 18.04 LTS to try.
If you have a device, it will be very easy to reproduce the problem. The steps are here https://www.kernel.org/doc/html/latest/admin-guide/acpi/initrd_table_override.html.
To be more specific. You can do these on your NUC device booted by Ubuntu 18.04 LTS:
sudo apt install -y acpica-tools
mkdir tmp
cd tmp
acpidum > acpidump
acpixtract -a acpidump
 You will get a bunch of .dat files. Then:
iasl -d *.dat
 It will generate .dsl files for every .dat.   A .dsl file is just a txt file.
Please check dsdt.dsl to see if there are any errors inside. Then:
iasl -sa dsdt.dsl
If you see no compile errors and file dsdt.aml is created. That will be great. Just let me know the version of acpica-tool installed.
If dsdt.aml is not generated and you see compile errors, it means this version of acpica-tools cannot interpret the firmware correctly. There must be a right version of acpica-tools to do this.
Harry
Ronny_G_Intel
Community Manager
Hi Harry,
Thanks for the details, yes I can test it but I need to first undertand what's wrong with the regular Ubuntu* 18.04 LTS deployment so that you need to use the acpica-tool.  I understand that this tool may be giving you errors but let me tell you that we usually dont provide support to 3rd party applications as our scope is limited to the Operating System installation especially when dealing with open-source software.
Even if I test it and get the errors you report, I need a strong justification to bring this over to the engineering team, this justification can vary from technical issues such as the Operating System not working as expected or business-related, for example, a BIOS feature request for a large number of units for a specific project.
Ronny G
harwang
Hi Ronny,
I understand your point completely. But from my point of view, I am actually not asking Intel to support any 3rd part application. I just need Intel to provide me the Firmware version information, so that I can find a right acpica-tools to work with.
acpica-tools' changes are reflecting the changes of ACPI tables format.  I can see ACPI 6.0 till 6.4 from ACPICA change log (https://acpica.org/sites/acpica/files/changes_59.txt).  What I need to know is which ACPI table format the NUC firmware is following.
It will be very helpful if you could tell me which acpica-tools is working with the firmware, but this is not the essence of the request.
Hope this can help your justification.
Thank you
Harry
Ronny_G_Intel
Community Manager
Hi @harwang,
I just got confirmation that we don't have the ACPI information readily available for customers. Find attached (NUC8PN_ACPI Dev.txt) the ACPI configuration for NUC8PN obtained by using a 3rd party utility "HWInfo64".
Keep in mind that that this tool is not developed, managed, or supported by Intel hence we are unable to make changes if required.
I hope this helps,
Ronny G
