Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13502 Discussions
NUC9VXQNX + TB3 Dock + Dual Screen
munklarsen
Hi all,
I have a NUC Quartz Canyon (NUC9VXQNX) with a 3060TI GPU added to it. The GPU drives a 4K display directly via a DP1.4 cable.
Besides that, I have a CalDigit TS4 dock the until recently only had a single display connected to it. It's a QHD display. I then recently added a second screen to the dock but I cannot get that to work.
From all the documentation I've read, it should be possible/supported for this NUC to drive two displays via a TB dock.
If I cannot the dock to a 3 year old Lenovo P1 laptop, it works just fine. Both the laptop display and the two QHD displays work just fine.
As for the setup:
  • NUC9VXQNX
  • Windows 11 21H2
  • Latest & Greatest BIOS/drivers/etc. Everything has been updated.
What am I doing wrong here?
n_scott_pearson
Super User Retired Employee
The DP 1.2 channel in the TBT3 stream is certainly capable of driving two QHD monitors. Each requires 5.63 Gb/s at 60Hz - a total of 11.26 Gb/s - and the DP 1.2 channel supports 17.28 Gb/s. If it is connecting in TBT3 mode (i.e., not in basic USB-C mode), it should work. Unfortunately, my TBT3 dock only supports a single monitor, so I cannot test this myself.
Only thing I can suggest is to ensure that the original monitor is not being clocked above 60Hz. If it is trying to maintain the original settings and this includes a clocking above 60Hz, then there will be insufficient bandwidth remaining to support the second monitor.
Hope this helps,
munklarsen
Just got this from CalDigit-support?
"We apologise for that. If the dock is working for one monitor at a time, and not both at the same time, this is an indication that the Thunderbolt ports on your NUC doesn't support dual displayport streams or is only 2 Lane rather than the needed 4 lane. We have seen this a lot since the introduction of Thunderbolt 3 on the Windows platform. Manufacturers can restrict the Thunderbolt ports in whatever way they see fit and have no strict requirements for Thunderbolt 3.
With Thunderbolt 3 on the Windows platform we have seen many different, varied, restrictions. These can include - only support a single monitor connection via Thunderbolt, not supporting 3rd party charging, USB ports don't work at all and docks consistently power cycling due to being blocked by the laptop manufacturer as it was 3rd party device."
Can anyone from Intel confirm?
DeividA_Intel
Hello munklarsen,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® NUC 9 Pro Kit - NUC9VXQNX.
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Provide the Report for Intel® Graphics Drivers:
3. What is the brand and model name of the 2 monitors/TV?
Deivid A.
DeividA_Intel
Hello munklarsen,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello munklarsen,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
munklarsen
Hi Deivid,
Sorry for the lack of reply but I've been away for the past week. I will gather what you asked for on sunday.
Many thanks.
