Intel® NUCs
Assistance in Intel® NUC products
13320 Discussions
NUC9i7QNB usb-c randomly works
Pete9
With bios version QXCFL579.
The usb-c randomly works; usualy the usb-c detects the external storage during boot time when connected.
Pete9
I had RMA back the NUC9i7QNB for refund, problem solved.
lEdge
And it works with every other computer so you are not blaming the cable?
I would blame the cable then maybe the port connection. I researched this a few times. The hard disk reserved volume for system volume information in windows os and relative osi operations is usually the problem that will cause lag like this. So softwares can reset this some companies just recall cable configurations.
Pete9
Its not the cable. Its either the bios or a faulty nuc element.
The thunderbolt port only functions during boot time.
lEdge
Try the begginer page. https://www.intel.com/content/dam/support/us/en/documents/intel-nuc/nuc-kits/NUC9QN_TechProdSpec.pdf
To be honest I personally hate reading PDF files in the computer screen, so I have a printer. Recommend a lot.
The USB-C and Thunderbolt 3 is discussed on pages 9 & 10.
And I read about this problem before about power getting disrupted in the actual housing sometimes. And the test was done with voltage volumeters with the support of USB-C docks of course.
As far as for Intel they should really try to bring some work into the & symbol. I just like to spell the few bronzing and letters. Just a personal preference again.
Pete9
