Intel® NUCs
11773 Discussions
Need 8i7HVK win8.1 Hardware driver
ZGGo
HI
I use this nuc for some special purpose,My APP needs to run in windows8.1 but Intel Driver and Support Assistant can't support.
Can the 8i7HVK be installed with the win8.1 system?
MLevi
Valued Contributor I
You could upgrade to windows 10 and run a Virtual Machine in Windows 8.1.
Also, if you have a Windows 10 machine, have you tried "compatibility mode" for your 8.1 application?
n_scott_pearson
Super User Retired Employee
No, it cannot. Only Windows 10 is supported on 7th generation and later processors.
Sorry,
MLevi
ZGGo
thank you ,The method you said I tried before, the effect is not good. Not a compatible issue, but a performance.
