Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
New 64bit 2008 Server reload on intel board. Amber Blinking Light, High fan RPM
Hello, long time reader first time poster. Fan seem to run very high, never slowing down. Amber blinking warning light on case. I have this link marked as a possible solution /message/142978# 142978 http://communities.intel.com/message/142978# 142978 , but that poster didn't mention having any warning lights going off. I ran sysinfo here is the result:
System Information Retrieval Utility Version 1.2
Copyright (c) 2010 Intel Corporation
Platform Firmware Inventory
BIOS Version....... S5500.86B.01.00.0060
BMC Firmware Version:
Op Code....... 00.58
PIA.............. 00.58
Boot Code.............. 00.18
ME Firmware Version:
Boot Code: 1.12.0070
HSC Firmware Version:
Boot Code: HSC_NOT_PRESENT
SDR Version:
SDR version: SDR Package 0.30
Sensors
sensor: version 1.49
-- BMC version 0.58, IPMI version 2.0
_ID_ SDR_Type_xx Sz Own Typ S_Num Sens_Description Hex & Interp Reading
0001 SDR Full 01 37 20 a 02 snum 10 BB +1.1V IOH = e8 OK 1.09 Volts
0002 SDR Full 01 3b 20 a 02 snum 11 BB +1.1V P1 Vccp = 97 OK 0.93 Volts
0003 SDR Full 01 3b 20 a 02 snum 12 BB +1.1V P2 Vccp = 97 OK 0.93 Volts
0004 SDR Full 01 3b 20 a 02 snum 13 BB +1.5V P1 DDR3 = ea OK 1.52 Volts
0005 SDR Full 01 3b 20 a 02 snum 14 BB +1.5V P2 DDR3 = e9 OK 1.51 Volts
0006 SDR Full 01 37 20 a 02 snum 15 BB +1.8V AUX = e8 OK 1.77 Volts
0007 SDR Full 01 33 20 a 02 snum 16 BB +3.3V = e6 OK 3.31 Volts
0008 SDR Full 01 38 20 a 02 snum 17 BB +3.3V STBY = e6 OK 3.31 Volts
0009 SDR Full 01 32 20 a 02 snum 18 BB Vbat = e7 OK 3.01 Volts
000a SDR Full 01 33 20 a 02 snum 19 BB +5.0V = e2 OK 4.95 Volts
000b SDR Full 01 38 20 a 02 snum 1a BB +5.0V STBY = ea OK 5.13 Volts
000c SDR Full 01 34 20 a 02 snum 1b BB +12.0V = e1 OK 11.88 Volts
000d SDR Full 01 34 20 a 02 snum 1c BB -12.0V = b5 OK -11.75 Volts
000e SDR Full 01 3b 20 a 02 snum 1d BB +1.35V P1 MEM = 00 State_7 0.00 Volts
000f SDR Full 01 3b 20 a 02 snum 1e BB +1.35V P2 MEM = 00 State_7 0.00 Volts
0010 SDR Full 01 39 20 a 01 snum 20 Baseboard Temp = 1d OK 29.00 degrees C
0011 SDR Full 01 3b 20 a 01 snum 21 Front Panel Temp = 1a OK 26.00 degrees C
0012 SDR Full 01 3b 20 a 01 snum 22 IOH Therm Margin = e0 OK -32.00 degrees C
0013 SDR Full 01 3b 20 a 01 snum 23 Mem P1 Thrm Mrgn = d7 OK -41.00 degrees C
0014 SDR Full 01 3b 20 a 01 snum 24 Mem P2 Thrm Mrgn = d5 OK -43.00 degrees C
0015 SDR Full 01 3a 20 m 04 snum 30 Processor 2 Fan = ff OK 7905.00 RPM
0016 SDR Full 01 3a 20 m 04 snum 31 Processor 1 Fan = ff OK 7905.00 RPM
0017 SDR Full 01 37 20 m 04 snum 33 System Fan 5 = cf OK 4140.00 RPM
0018 SDR Full 01 37 20 m 04 snum 35 System Fan 3 = 00 Crit-lo 0.00 RPM
0019 SDR Full 01 37 20 m 04 snum 37 System Fan 1 = b4 OK 2520.00 RPM
001a SDR Full 01 37 20 a 0b snum 52 PS1 Power In = 16 OK 88.00 Watts
001b SDR Full 01 37 20 a 0b snum 53 PS2 Power In = 16 OK 88.00 Watts
001c SDR Full 01 39 20 a 03 snum 54 PS1 Curr Out % = 08 OK 8.00 unspecified
001d SDR Full 01 39 20 a 03 snum 55 PS2 Curr Out % = 06 OK 6.00 unspecified
001e SDR Full 01 3a 20 a 01 snum 56 PS1 Temperature = 2f OK 47.00 degrees C
001f SDR Full 01 3a 20 a 01 snum 57 PS2 Temperature = 2f OK 47.00 degrees C
0020 SDR Full 01 3a 20 a 01 snum 62 P1 Therm Margin = c1 OK -63.00 degrees C
0021 SDR Full 01 3a 20 a 01 snum 63 P2 Therm Margin = ba OK -70.00 degrees C
0022 SDR Full 01 3a 20 a 01 snum 64 P1 Therm Ctrl % = 00 OK 0.00 unspecified
0023 SDR Full 01 3a 20 a 01 snum 65 P2 Therm Ctrl % = 00 OK 0.00 unspecified
0024 SDR Comp 02 2a 20 a 09 snum 01 Pwr Unit Status = 00 c0 00 00 Enabled
0025 SDR Comp 02 2a 20 a 09 snum 02 Pwr Unit Redund = 00 c0 01 00 Redundant
0026 SDR Comp 02 28 20 a 23 snum 03 IPMI Watchdog = 00 c0 00 00 OK
0027 SDR Comp 02 29 20 a 05 snum 04 Physical Scrty = 00 c0 00 00 OK
0028 SDR Comp 02 2a 20 a 13 snum 05 FP NMI Diag Int = 00 c0 00 00 OK
0029 SDR Comp 02 26 20 a f3 snum 06 SMI TimeOut = 00 c0 00 00 Disabled
002a SDR Comp 02 2b 20 a 10 snum 07 System Event Log = 00 c0 00 00 OK
002b SDR Comp 02 27 20 a 12 snum 08 System Event = 00 c0 00 00 OK
002c SDR Comp 02 25 20 a 08 snum 50 PS1 Status = 00 c0 01 00 Present
002d SDR Comp 02 25 20 a 08 snum 51 PS2 Status = 00 c0 01 00 Present
002e SDR Comp 02 24 20 m 07 snum 60 P1 Status = 00 c0 80 00 OK*
002f SDR Comp 02 24 20 m 07 snum 61 P2 Status = 00 c0 80 00 OK*
0030 SDR Comp 02 25 20 m 01 snum 66 P1 VRD Hot = 00 c0 00 00 OK
0031 SDR Comp 02 25 20 m 01 snum 67 P2 VRD Hot = 00 c0 00 00 OK
0032 SDR Comp 02 21 20 m 07 snum 68 CATERR = 00 c0 00 00 OK
0033 SDR Comp 02 26 20 m 07 snum 69 CPU Missing = 00 c0 00 00 OK
0034 SDR Comp 02 2b 20 m 01 snum 6a IOH Thermal Trip = 00 c0 00 00 OK
0035 SDR Comp 02 21 20 a 14 snum 09 Button = 00 c0 00 00 OK
0036 SDR Comp 02 2a 2c a dc snum 1a NM Capabilities = ea c0 00 00 OK
0037 SDR EvtO 03 19 2c 00 snum 17 SPS FW Health = e6 c0 00 00 OK
0038 SDR EvtO 03 18 2c 00 snum 18 NM Exception = e7 c0 00 00 OK
0039 SDR EvtO 03 15 2c 00 snum 19 NM Health = e2 c0 00 00 OK
003a SDR EvtO 03 18 2c 00 snum 1b NM Threshold = e1 c0 00 00 OK
003b SDR EvtO 03 1b 33 01 snum 01 Mem Mirr Sensor = 00 c0 00 00 OK
003c SDR EvtO 03 1b 33 01 snum 11 Mem Spar Sensor = 97 c0 00 00 OK
003d SDR EvtO 03 1b 33 01 snum 02 Mmry ECC Sensor = 00 c0 01 00 Warn-lo
003e SDR EvtO 03 1b 33 01 snum 03 PCI Lgcy Sensor = 00 c0 00 00 OK
003f SDR EvtO 03 1b 33 01 snum 04 PCIe Fat Sensor = 00 c0 00 00 OK
0040 SDR EvtO 03 1b 33 01 snum 05 PCIe Cor Sensor = 00 c0 00 00 OK
0041 SDR EvtO 03 1b 33 01 snum 12 Mirr Mod Sensor = 97 c0 00 00 OK
0042 SDR EvtO 03 1b 33 01 snum 13 Spar Mod Sensor = ea c0 00 00 OK
0043 SDR EvtO 0...
Tags (1)
Highlighted
Valued Contributor III
536 11-10-2011-11:01:40 AM Fan System Fan 3 (# 0x35) CRITICAL event: System Fan 3 reports the sensor is in a low, critical, and going lower state. Sensor reading: 0 RPM. Threshold value: 324 RPM. BMC - LUN# 0 (Channel# 0
Either the SYS 3 fan has failed, or you have it connected to the wrong header.
( I love sysinfo- all the data in one place)
Highlighted
Community Manager
Hey Doc.... well, funny thing is I am unable to log onto the Intel community with the same email that I used to post the original question in this thread. I wanted to tell you that I am going to do some work on this server now. I wanted to also say that the question was answered. I will continue to try to log into the original account. Thanks for your response. Getting ready to crack it open and do some work on it..
Highlighted
Community Manager
Actually Doc, we are not even using that fan.. Its an empty header. I think I need to re-run FRUSDR to define the correct chassis and fan configuration.
Highlighted
Community Manager
Had a key that started malfunctioning on my keyboard. So I had to swap out before I could log into this original account and password. FInally. So, thanks Doc. Will post if re running the FRUSDR is my fix. ONe question though.. there are 4 fan headers on this mobo, and 2 are black, and 2 are blue.. Best I can tell, i am using 1 and 2 (black), and 3 and 4 are unused (and blue) wonder what the significance of that is?
