Intel® NUCs
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
12546 Discussions
No Bios and No HDMI output by NUC8i7BEH
ELehr
i have now a mini PC kit NUC8i7BEH.
on this i installed Windows 10, for testing, then i installed Kubuntu 18.04 over Win10.
so too beginn i can go in Bios to disable secureboot.
Now I have the following problems:
- i cannot got to Bios anywehre
- i dont have any picture on boot (no Intel screen, no Bios, no Linux-Grub), and the system is black with sending "no Signal on HDMI"
also i have no picture until Linux is booted.
So i have treid these:
https://www.intel.com/content/www/us/en/support/articles/000005847/mini-pcs.html?_ga=2.181088737.753... Can't Access BIOS Setup with F2 Key for Intel® NUC
Fastboot is not enable!
I tried the NUC on a monitor and on a TV
on this side, i cannot find any Tools or Bios-upgrade for flashing bios new?
https://ark.intel.com/de/products/126140/Intel-NUC-Kit-NUC8i7BEH Intel® NUC Kit NUC8i7BEH Produktspezifikationen
So the next try was:
https://www.intel.com/content/www/us/en/support/articles/000005805/mini-pcs.html Clearing CMOS on Intel® NUC
But is the same thing, no Bios and no Picture on HDMI until Linux is booted.
Can someone help or give tips what I could try.
LeonWaksman
Hello EgLe
The Linux is not supported in NUC8i7BEH. Looks that some bios boot data where overwritten after Linux installation. If you want run Linux on this NUC, I suggest that you will do this fro Virtual Machine. Here you have link how to enable Hyper-V on Windows 10 Pro: https://docs.microsoft.com/en-us/virtualization/hyper-v-on-windows/quick-start/enable-hyper-v Enable Hyper-V on Windows 10 | Microsoft Docs .
In your case I would try to recover bios from Power Button Menu. Since, I don't find any bios release for your NUC yet, I can't recommend it now. So, in this situation try to disconnect the Power Adapter cable and then disconnect the connector of CMOS battery for 15 minutes.
Still you can access bios from Power Button Menu. To get Power Button Menu, press Power Button for about 3 seconds. You should release the Power Button soon as the power led changes color from blue to amber. Alternately, the system will emit three short beeps from the PC speaker or headphones, if connected, then stop. If you see the LED color change or you hear the beeps, release the Power Button - NUC shall reboot into Power Button Menu.
Once in Bios disable the Secure Boot.
Leon
LeonWaksman
Hello EgLe
Leon
ELehr
Hello lw1484,
Many Thanks, this was the right answer
Okay now i can accses to the Bios, and now i have install Windows 10..... (is not my system)
Hmm, bad think one problem is solved, another problem is Windows 10
But this is a topic for a new thread
Okay, I have a pre-production engineering sample here.
But it can't be that Windows 10 is faulty, and a Kubuntu 18.04 runs perfectly only just damaged the bios.
I would say that this is still a BIOS bug, and hopefully will be fixed.
ELehr
Hello lw1948,
You wrote:
Hello EgLe
So, now with the new Software and BIOS on this page:
https://downloadcenter.intel.com/de/product/126140/Intel-NUC-Kit-NUC8i7BE Downloads für Intel® NUC-Kit NUC8i7BEH
https://downloadcenter.intel.com/de/download/27987/BIOS-Update-becfl-357-86-a-?product=126140 Download BIOS Update [becfl 357.86 a]
Linux is Working very fine
Now i have a new Dualboot-System with Windows 10 and Manjaro Linux KDE Edition (17.1.12)
Installation and working without any Problem by me.
Possibly it can be that with the sound output over HDMI the clay/tone croaks a little. At least this is still the case with my NUC8i7HVK.
But this is due to the linux drivers, and will hopefully be improved in the future.
But here I used a BenQ monitor without sound output, so the sound is simply sent via the external sound boxes without any problems.
And the best, the new Bios now makes no problems with the Linux!
[monika@NUC8i7BEH ~]$ inxi -F
System: Host: NUC8i7BEH Kernel: 4.14.65-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.13.4
Distro: Manjaro Linux
Machine: Type: Desktop System: Intel product: NUC8i7BEH v: J72992-301 serial:
Mobo: Intel model: NUC8BEB v: J72688-302 serial: UEFI: Intel
v: BECFL357.86A.0041.2018.0719.1931 date: 07/19/2018
CPU: Topology: Quad Core model: Intel Core i7-8559U bits: 64 type: MT MCP L2 cache: 8192 KiB
Speed: 453 MHz min/max: 400/4500 MHz Core speeds (MHz): 1: 439 2: 435 3: 443 4: 486 5: 474 6: 494
7: 442 8: 445
Graphics: Device-1: Intel driver: i915 v: kernel
Display: x11 server: X.Org 1.20.1 driver: intel unloaded: modesetting resolution: 1680x1050~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics (Coffeelake 3x8 GT3) v: 4.5 Mesa 18.1.7
Audio: Device-1: Intel driver: snd_hda_intel
Sound Server: ALSA v: k4.14.65-1-MANJARO
Network: Device-1: Intel driver: iwlwifi
IF: wlp0s20f3 state: down mac: 7e:7b:80:71:00:b4
Device-2: Intel Ethernet I219-V driver: e1000e
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: 94:c6:91:1d:9a:42
Drives: Local Storage: total: 238.47 GiB used: 7.38 GiB (3.1%)
ID-1: /dev/sda vendor: Intel model: SSDSCKKW256G8 size: 238.47 GiB
Partition: ID-1: / size: 112.70 GiB used: 7.36 GiB (6.5%) fs: ext4 dev: /dev/sda4
ID-2: swap-1 size: 7.64 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 38.0 C mobo: 27.8 C
Fan Speeds (RPM): N/A
Info: Processes: 210 Uptime: 11m Memory: 7.66 GiB used: 882.9 MiB (11.3%) Shell: bash inxi: 3.0.21
Now I am really very happy with this Intel-NUC
But of course the best thing is that even this Linux with Kernel 4.14 has no driver problems and everything works right away.
Time to install the brand new Kernel 4.19 rc1
I just love Linux
LeonWaksman
Hello EgLe ,
1. I'm very glad that you have succeeded to install Linux and that you like your NUC now,
2. I got some link from al.hill which may be of some interest for you: https://docs.microsoft.com/en-us/windows/wsl/install-win10 Install Windows Subsystem for Linux (WSL) on on Windows 10 | Microsoft Docs
Leon
Christoper_C_Intel
Where did you get your hands on one of these? Can't find them anywhere.....
ELehr
Hello ccallana
Sorry, I don't understand what you mean.
But.......
Thanks, the whole thing has been done, now there are own drivers on the download page Inclusive new Bios version :-)
https://downloadcenter.intel.com/de/product/126140/Intel-NUC-Kit-NUC8i7BEH Downloads für Intel® NUC-Kit NUC8i7BEH
So this thread is done by itself. (Hopeful)
The new Bios is install, and booting Linux from USB-STick is okay, next weekend i test a Dualbootsystem with Manjaro-Linux
Thanks for your help
Christoper_C_Intel
EgLe Where did you buy the NUC8i7BEH?
n_scott_pearson
Super User Retired Employee
He didn't. Look above; he said: "I have a pre-production engineering sample".
