Hi.
A few weeks ago I bought a NUC8i3BEH from Amazon. I purchased a Windows 10 Pro license to be able to run Windows on it just in case, even though I bought it as a powerful retrogaming machine, with a dedicated Linux-based OS (RecalBox). I also installed Ubuntu as well.
While I see both Recalbox and Ubuntu's GRUB boot options, I can't get to install the Windows Boot Manager option in the NUC's BIOS. The strangest thing is GRUB sees Windows Boot Manager and boots it if selected.
Is there a limit on the number of boot options in the NUC's BIOS? If not, how do I solve this ?
Thanks in advance.
Hi @moisemust
There is a limited number of boot entries in BIOS. Could be that the Windows Boot Manager isn't visible in BIOS and/or Boot Menu, because you have to much entries there. Please check this and delete some old and not used entries (if any).
This video show how to do this from Windows. This is an additional method.
This video shows how to do this in Linux (using efibootmgr).
Leon
Hi @moisemust
You should disable the Secure Boot option in BIOS. There is lot of articles on net dealing with Dual Boot installation. See this tutorial for an example.
Leon
I forgot to mention it, but I did disable secure boot already, otherwise Ubuntu wouldn't install.
What kind of drive are you (or want to be) booting from? If it is NVMe, then you *must* use UEFI Boot.
I'm using UEFI Boot though (Legacy is even disabled and Windows boots fine from Grub).
I am no expert on Grub, but I have always thought that it was necessary to install Windows before Linux. This may be why it is not working.
I did the installs twice, as every time Windows Boot Manager wouldn't appear in the BIOS. It still doesn't. I also tried a few commands from the Windows install USB (created with the 2004 mediacreationtool provide by Microsoft on their website).
I also checked the EFI partition, the necessary files for booting Windows are present (at least the same as on my other desktop, which uses UEFI, are there).
Hi @moisemust
Leon
Hello @moisemust
We hope that the information provided by the community has been helpful to clarify your concern. Since the thread has been marked as "Solved" we will proceed to close this inquiry now from our end. Communications with community peers may continue, but if you need any additional information from Intel, please submit a new question as this thread will no longer being monitored.
Andrew G.
