Intel® NUCs
12121 Discussions
No boot via PXE after disabling WLAN
MB_2
NUC6CAYB
Bios : AYAPLCEL.86A.0055.2018.0821.1152
The NUC is connected via LAN cable and booting via PXE - everything fine so far.
When i disable the Onboard-WLAN Controller under "Onboard Devices" the machine doesn't boot any longer - even not
from LAN!
Enabling WLAN again - everything works fine again.
Is this a known bug? Or is there any hidden Option or Trick?
Community Manager
Hello mbit85
Thank you for posting in the Intel® community.
I have not heard about this behavior to better assist you please provide me the following info:
  1. Run the utility.
  2. Click on "Scan" to get the scanned system.
  3. Once the scan is complete click on "next".
  4. Use the "save" option, save the report to your desktop.
  5. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Hope this helps.
Leonardo C.
Under Contract to Intel Corporation
MB_2
- no strorage devices / no OS running
- Memory - 4GB S0DIMM1 on Memory Channel A - Memory Speed 1866 MHz - no idea which brand while i ordered the nuc as barebone machine on amazon including RAM
- no led light behavior - constantly blue all the time
- if turning off WLAN - starting up the machine - Intel NUC logo appears as usual then after a few seconds jumps to a black screen and says "A bootable device has not been detected"
While there is no storage in the machine / no OS it's a bit tricky to use the support utility.
Any further advice?
Community Manager
Hello mbit85
Thank you for the information.
How do you have set up the BOOT configuration Tab on the BIOS? Please share a picture.
Leonardo C.
Community Manager
Hello mbit85
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
