Intel® NUCs
12301 Discussions
No network found during Windows installation: BXNUC10I7FNK1
SParr7
I received a nuc a day ago and I've been trying to install windows on it. Launching from a windows intallation on USB, everything seems fine. Windows installation proceeds, copies files etc. but at the network screen says there is no network!
I have an ethernet cable plugged in which i know is good (i've swapped it out etc.). It's plugged into a switch - the switch has 2 flashing green leds and the nuc has a solid orange and flashing green (from L to R).
Any idea what i need to do here? Faulty port?
n_scott_pearson
Super User Retired Employee
Make sure that you are running on the latest available BIOS released (update if not the latest) and then verify that the default configuration is loaded. This should result in the ethernet port being enabled.
SParr7
Hi
Thanks for replying. Actually this didn't work, there was a slightly newer bios, but same thing.
here's what worked:
  • i downloaded the complete intel ethernet driver pack (an exe) to another desktop i have and unzipped.
  • Copied to a flash drive
  • Ran windows set up on the NUC and at the driver installation prompt, pointed it to the last folder in the PRO1000 directory
  • This then copied a driver over with the windows files
  • Hey preso - i have a networked NUC
Honestly - i'm super surprised i needed to do this at all - what computer do you buy these days where you need to fiddle around with finding and installing specific drivers?
Hmmm...
AlHill
"what computer do you buy these days where you need to fiddle around with finding and installing specific drivers?"
Most all of them.
Doc
SParr7
During installation of windows? For an Ethernet controller? Seems odd to me...
