Hello sariut,
1. Are you using an Intel® NUC 8 Rugged Kit NUC8CCHKR? If not, please specify which NUC model are you using?
2. Can you explain in more detail what the problem is? Is this no video problem over which video port? What is the LED behavior when you turn on the NUC and how do you turn it off? Please explain.
3. Provide the brand and model number for: RAM memory, SSD/HDD drive.
4. Have you tried turning the system on with minimal configuration? I.e. just using the power supply, CPU (embedded), included RAM, and storage (no extra components).
5. Have you tried different video cables and different monitors?
6. Did this system use to work before? If yes, did you make any changes before the issue started?
Sebastian M
Hello sariut,
Thanks for the response.
Based on what you are reporting, I will recommend you to try a BIOS recovery using the BIOS Recovery by Security Jumper method described here: https://www.intel.com/content/www/us/en/support/articles/000033291/intel-nuc.html. BIOS download: https://downloadcenter.intel.com/download/29994/BIOS-Update-CHAPLCEL-
If that does not work, I will recommend you to check the warranty replacement options for this unit; in order for you to do that, you may want to contact us directly, feel free to refer to this thread once you contact our support team https://www.intel.com/content/www/us/en/support/contact-support.html
Sebastian M
Hello sariut,
We apologize for any inconvenience this may cause you. Since we completed the troubleshooting our next recommendation is to contact the Intel* internal support, they can help you to verify and complete the warranty of your unit.
Here are pages where you can look up contact information, including local/country phone numbers, by geography:
- U.S. and Canada: Intel Customer Support NA
- Europe, Middle East, and Africa: Intel Customer Support EMEA
- Asia-Pacific: Intel Customer Support APAC
- Latin America: Intel Customer Support LAR
Maria R.
