Hello Community,
unfortunetly I can´t figure out how to connect both of the devices with a HDMi cable. I tried different (modern and short) cables on different ports. All I get is a MS Windows starting screen, but most of the time the MI TV reports "No signal".
As another device I use an old 2009 SEG Orion Flatscreen. On this device everything is fine with picture/audio - any cable or port I use.
Has anyone an explanation for this?
Thanks for answers in advance
Eckart
Have you tried plugging the NUC into all of the HDMI ports on the TV? Some TVs will only work if the PC is plugged into a specific HDMI connector. Have you verified that the correct input has been selected?
Hope this helps,
