Intel® NUCs
NuC6i7kyk
Stevo75
Hallo..nach einem bios update auf Version 074.bio funktionierte das Gerät nur noch kurz und ging dann aus..
Power Recovery Menü funktioniert nicht.. Security jumper Weg läuft durch,aber danach bootet er auch nicht..keine Bildausgabe und der Lüfter dreht auf voller Leistung..
Ist der bios chip evtl defekt?
n_scott_pearson
Super User Retired Employee
Defective? Unlikely. Corrupted? Possibly.
I would disconnect power, open the chassis and unplug the CR2032 CMOS Backup Battery for 15 minutes. [Aside: since it is 4-5 years old, I might suggest that you consider replacing this battery as well.] After putting the unit back together, again attempt to use the jumper-based BIOS Recovery process. If this works, remember to go into BIOS Setup, insert the proper Date and Time and verify your BIOS Configuration.
Hope this helps,
David_G_Intel
Hello @Stevo75
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, I am glad to see that fellow community members have the knowledge and they jumped in and helped. You may also find the Discontinued Products website (https://www.intel.com/content/www/us/en/support/discontinued-products.html) website helpful to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued". https://ark.intel.com/
David G
