Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Nuc 2820 hdd connection problem, doa
Hello from Greece, I bought a Nuc two days ago but bios does not detect any ssd or hdd. If you connect the hdd directly from motherboard and give it power externally from a nearby pc then the hdd shows up in the bios. Probably the problem is a defected cable or more likely the small chip with the hdd socket.
I want to ask if the Nuc will be replaced or repaired and do I have to contact the retailer or I have to find the authorised dealer in Greece ?
Thanks you
Highlighted
Re: Nuc 2820 hdd connection problem, doa
Thanks a lot for contacting us Kyrliot. In regards to your inquire, since the product was purchased less than 1 month ago, I will suggest you to contact the place of purchase in order to get a brand new product.
Just in case this is the list of tested peripherals
http://www.intel.com/support/motherboards/desktop/dk-dn2820fyk/sb/CS-034622.htm http://www.intel.com/support/motherboards/desktop/dk-dn2820fyk/sb/CS-034622.htm
