Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13512 Discussions
Nuc 5i3myhe and Ssd pro m2 5450s
GDubo3
the Nuc 5i3MYHE does not recognize the Ssd m2 pro 5450s. Ssd not installed the bios. The bios is up to date. Why? The 2 materials have the same Sata interface?
LeonWaksman
  1. Did you enabled M.2 slot in Bios settings? Advanced > Devices > PCI
  2. Reset again the SSD in M.2 2280 slot .
3. Can you check this SSD in other computer?
Leon
GDubo3
Bios ​Advanced > Devices > PCI>>>>>not populated
I tested the Ssd on a usb reader. The led of the reader flashes but the Ssd is not recognized under W10.
LeonWaksman
Assuming that in Bios Advanced > PCI the M.2 slot is checked (M.2 enabled), probably the SSD is failed.
Leon
GDubo3
I too believe that the SSD is dead.
Thank you all for your responses
