Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Nuc 7i7BNH - screen goes blank (black) periodically in Windows 10 64 bit.
Jump to solution
Issue:
Since upgrading to the newest bios BNKBL357.86A.0048.EB.EXE my display periodically goes blank (black) for a few seconds and then returns to normal. This happens several times an hour.
All drivers are up to date according to the Intel Update utility. Video driver version is 15.45.19.4678.
I am using Windows 10 64 bit, version 1703, OS build15063.483
It looks a lot like this:
https://www.youtube.com/watch?v=YZGoSVcJgpE NUC NUC6i5SYH and LG 31MU97 flickering on DP - YouTube
Equipment:
Intel Nuc7i7bnh
32gb ram
Samsung 960 evo ssd
Dell 2415Q 4k monitor (Single display)
USB C (Thunderbolt) to displayport cable - StarTech.com USB C to Display port cable
Accepted Solutions
Highlighted
Community Manager
Hello azguy,
Thank you for contacting the Intel community.
I'm sorry for the issue that you are experiencing with the Intel® NUC.
DougArcher is right, this issue seems to be the same he reported on the other thread and we are working on a solution, unfortunately I don't have an estimated time when this is going to be fixed but hopefully a new graphics driver will be release soon to solve this problem.
As DougArcher said if you are running a 4k resolution at 60Hz the temporally solution is to lower down the refresh rate to 30Hz.
For an update related to this problem please keep checking here:
/thread/116126 https://communities.intel.com/thread/116126
Best wishes,
Ivan U.
Highlighted
I think you're having the same problem as me:
I noticed in the video you're running the display at 60Hz. As a temporary solution, when I set the refresh rate to 30Hz the flickering is dramatically reduced. If you read my thread, you'll see it's most likely a driver problem, the intel rep has been able to reproduce it, and it's being "worked on". Hopefully we see a fix soon.
Highlighted
Community Manager
Hello azguy,
Best wishes,
Ivan U.
Highlighted
The new graphics driver does NOT resolve the flickering issue. (GFX_WIN10_64_15.46.2.1.4729)
Watching this video nearly always creates the issue for me:
http://www.azcardinals.com/videos/videos/CardsCamp-Highlights---Full-Pads-/2a728f0b-b120-4d4b-9726-3... # CardsCamp Highlights - Full Pads
This video plays correctly on a 2012 MacBook Pro running Mac OS 10.12.6
Interestingly, this video also plays correctly on my Nuc7i7 if I totally uninstall the Intel video driver and instead use the Microsoft driver.
Highlighted
I work for Intel Customer Support and I want to let you know that we are aware of screen flashing and/or flickering issue when using 4K resolutions on NUC7ixBN systems.
This issue has been reported and engineering is working on finding a solution for it.
I am trying to locate all community threads related to this issue to refer them back to the following one and consolidate: /message/490689# 490689 NUC7ixBN Screen Flashing/Flickering when using 4K resolutions <</span>/thread/116824 https://communities.intel.com/thread/116824> We will keep this community thread updated with any progress we make.
I apologize for any inconvenience this may have caused or is still causing and I appreciate your help and patience.
I will be locking up this thread to make sure all comments are properly tracked and followed on /message/490689# 490689 NUC7ixBN Screen Flashing/Flickering when using 4K resolutions
Ronny G
