Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13483 Discussions
Nuc 9 extreme kit egpu only in bios
Sad972
Do Intel have a bios version where it's possible like in the nuc8 to choose egpu only for display.
It is almost impossible to boot on egpu with the nuc 9 if we have a another graphic card installed.
So let's say I want my epgu for gaming and the pcie GPU for calculs ???
AlHill
Which NUC 9?   Be specific and provide the model number.
Sad972
Bxnuc9i7qnx.
It work after a multiple reboot so each time it's two or three try before I get display. Now I know if the screen don't show up before the keyboard emit light press the power button for 10sec and try again...
Jean_Intel
Hello Sad972,
If you may let me jump into the conversation, I would like to add the following:
Since you mentioned that this issue is solved after multiple reboots, this may be the expected behavior. During the first boot, after a power cycle, the eGPU waits until the eGPU driver takes over when the system boots into the operating system. After the eGPU driver is enumerated, the system can identify the eGPU attached to the Thunderbolt port. and at the second, the Intel® NUC will set the primary display to the eGPU path.
For further troubleshooting steps and information about eGPUs on Intel Nuc systems, you should visit this article.
Best regards.
Jean O.
Jean_Intel
Hello Sad972,
I hope you are doing fine.
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
