Buongiorno, ho acquistato da pochi giorni Nuc Ghost Core i5 9th
Purtroppo non da alcun segnale video il Nuc si accede dopo circa 15 secondi inizia a lampeggiare il led e tutte le ventole si fermano,
ho fatto diversi tentativi cambiando monitor o cavi ma nessun risultato,
premendo F2 non succede nulla non da alcun segnale video
cosi equipaggiato
2 banchi 8 GB Crucial DDR4 2666 SoDIMM 1.2 V
1 SSD Samsung 970 EVO
un felice possessore, ma disperato chiedo il vostro aiuto
MaurizioItaly, Thank you for posting in the Intel® Communities Support.
Just to let you know, we only provide support in English language and currently, we are using a translation tool.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the specific model of the Intel® NUC?
What is the model of the monitor?
When did you purchase the Intel® NUC?
Which video ports are you using?
Are you using adapters or converters to connect it to the monitor?
Was it working fine before?
When did the issue start?
Did you make any recent hardware/software changes?
Albert R.
Hello MaurizioItaly, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Hello MaurizioItaly, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
