Intel® NUCs
12124 Discussions
Nuc + Receiver - no center audio
TDast1
Currently running the following setup on my new nuc
NUC7i3BNH on Windows 10 Pro
Yamaha RX-V483
I have updated bios, drivers, everything, but I cannot get my center speaker to work. If I run the "configure speakers" test it is able to chime the center speaker, but when I try to play any media no audio comes out of the center speaker. I am at my whit's end with this and cannot find a solution.
Any advice?
Community Manager
Hello mitsitsad,
Thank you for joining our Intel ® Community, I will help you further with your issue.
In this case, please provide me the report generated by our https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-Best Intel® System Support Utility for Windows*
To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Let us know, when did the issue start?
Is the issue happening only with your NUC7i3BNH?
Does it happen with a different computer/system?
Have you performed any Windows* update recently?
Based on the https://usa.yamaha.com/support/updates/rx-v483_rx-v583_rx-a660_htr-4071_htr-5071.html Yamaha's Website, you can check the unit's firmware to make sure that you do not have to perform any update on it, if your firmware version is 2.58 or higher; the AV receiver is already up-to-date, if it is not, please go ahead and install it using the link above.
On the remote control, press the SETUP button.
Select "Network" > "Network Update". Your current firmware version will be displayed on TV.
I hope to hear from you soon.
Diego S.
TDast1
I just set this system up, so it has been this way since inception
Bluetooth, other sources, etc stream through all channels - it is only the nuc that is giving me an issue
Windows is up to date, no updates have caused it to work or stop working
Yamaha receiver firmware is up to date.
Like I said, when I configure the speakers in the Intel HD Audio settings it does chime the center speaker, so it is aware that it is there. but any other audio, even just adjusting the volume chime, no audio comes through the center channel
Community Manager
Thank you for that information.
Can you please help us to gather your https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-Best Download Intel® System Support Utility for Windows* report? We would like to take a closer look to your configuration.
Amy C
Under Contract to Intel Corporation
TDast1
# SSU Scan Information
Scan Info:
Version:"2.5.0.12"
Date:"09/26/2018"
Time:"00:00:33.5025054"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Intel Corporation"
BIOS Mode:"UEFI"
BIOS Version/Date:"Intel Corp. BNKBL357.86A.0068.2018.0824.1125 , 08/24/2018 12:00 AM"
CD or DVD:"Not Available"
Embedded Controller Version:"8.15"
Platform Role:"Desktop"
Processor:"Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz , GenuineIntel"
Secure Boot State:"Off"
SMBIOS Version:"3.1"
Sound Card:"Intel(R) Display Audio"
Sound Card:"Realtek High Definition Audio(SST)"
System Manufacturer:"Intel Corporation"
System Model:"NUC7i3BNH"
System SKU:"Not Available"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"24.20.100.6229"
- "Intel(R) HD Graphics 620"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1.00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) HD Graphics 620"
Link:" http://www.intel.com/content/www/us/en/search.html?keyword=HD+Graphics+620"
CoInstallers:"C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_cb4895b021d464bf\igxpco64.dll, CoDeviceInstall"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmd64.sys"
Driver Date:"06/19/2018 08:00 PM"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\igdlh64.inf_amd64_cb4895b021d464bf\igdkmd64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"24.20.100.6194"
INF:"oem21.inf"
INF Section:"iKBLD_w10_DS"
Install Date:"Not Available"
Installed Drivers:"C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_cb4895b021d464bf\igdumdim64.dll,C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_cb4895b021d464bf\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_cb4895b021d464bf\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_cb4895b021d464bf\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_5916&SUBSYS_20688086&REV_02\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"60 Hz"
Refresh Rate - Maximum:"60 Hz"
Refresh Rate - Minimum:"23 Hz"
Resolution:"3840 X 2160"
Scan Mode:"Noninterlaced"
Service Name:"igfx"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) HD Graphics Family"
- "Memory"
Physical Memory (Available):"1.50 GB"
Physical Memory (Installed):"4 GB"
Physical Memory (Total):"3.89 GB"
- "BANK 0"
Capacity:"4 GB"
Channel:"ChannelA-DIMM0"
Configured Clock Speed:"2133 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"SODIMM"
Interleave Position:"Noninterleaved"
Manufacturer:"8502"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"PSD44G213381S"
Serial Number:"00000000"
Status:"Not Available"
Type:"Not Available"
- "Motherboard"
BIOS:"BNKBL357.86A.0068.2018.0824.1125, INTEL - 44"
Caption:"Motherboard"
Chipset:"Not Available"
Date:"08/23/2018 08:00 PM"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"NUC7i3BNB"
Serial Number:"GEBN7340065H"
Status:"OK"
Version:"J22859-3...
TDast1
Let me know if this helps solve the issue
TDast1
I did some research and found a solution last night. I think one of the problems lies within Windows 10, where 5.1 audio and stereo audio settings are reversed. I switched my setup to "stereo" and it was better. I then messed with the scene programs on my Yamaha receiver and was able to get center audio full time.
