Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Nuc i5 Haswell (D54250WYKH) Temperature issue and Noisy Fan
Yesterday I installed a Nuc D54250WYKH.Right from the start,I found it very noisy.
Setup:
WLA/Dual Band Wireless-AC 7260
SSD Crucial M500 120GB CT120M500SSD1
Kingston ValueRAM 8 GB KVR16LS11/8
On Visual Bios CPU Core Temp is very high 80-85ºC and fan about 6.000 RPM . I attached a screenshot.
I Installed a Windows 7 SP1 and when the processor works just at 10 %, the temperature of the cores ups quickly ( 80-85º ) and the fan becomes very noisy
I have installed other NUCs and is the first time that i have this problem
I am wondering, has anyone else experienced this issue? Any Fixes ?
I also noticed that the battery is not fixed and moves
Tags (1)
Highlighted
Re: Nuc i5 Haswell (D54250WYKH) Temperature issue and Noisy Fan
Hello Enrique, I would like to tell you that we have seen this noise issue before and it has been escalated and our engineers. They are trying to find a solution for this. Please check the following thread /thread/47989 https://communities.intel.com/thread/47989
Regarding the temperature, please be aware that the maximum temperature allowed at the processor die is around the 100°C. Are you using the thermal pad?
