Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13500 Discussions
Nuc12pro (nuc12wsbi5) bios setting to prevent waking up monitor ?
nightrhyme
Hi
would like to prevent my nuc from constantly waking up my tv. On boot, on resume from standby. As in never ever wake up my TV. Can’t seem to find a bios setting that works?
thanx in advance
Alberto_R_Intel
nightrhyme, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, try to reset the BIOS to default values by pressing F9 and then F10 to save and exit.
If the problem persists after that, just to confirm:
What is the model of the TV?
Which video port are you using to connect the Intel® NUC to the TV?
Was it working fine before without waking the TV up?
If yes, when did the issue start?
Did you make any recent hardware/software changes that might cause this issue?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
nightrhyme
Thanx for reply
However I already fixed the issue myself.
It was the HDMI-CEC setting
Bios, Advanced, Onboard devices, HDMI CEC control=Uncheck (disable)
Alberto_R_Intel
nightrhyme, You are very welcome, thank you very much for your response.
Thank you very much as well for taking the time to share the solution, we are sure it will be very useful and helpful for all the peers looking at this conversation.
Any other inquiries, do not hesitate to contact us again.
Albert R.
