Community
cancel
Showing results for
Search instead for
Did you mean:
CChen35
Nuc6i7kyk 溫度居高不下 時常飆破100度c 及 顯示驅動會造成adobe premiere pro 2018畫面呈現綠色的問題
你好:
有人的nuc6i7kyk溫度常常破100度c嗎?
我的電腦最近安裝個驅動程式或是上個網頁都能飆到80~100度
待機時溫度都在66度左右,剛買這台電腦的時候我記得待機溫度是在45~50度之間
最近明顯有異常
有時畫面會閃黑一下,感覺好像顯示有點問題
另外
我安裝
版本23.20.16.4944 和 版本24.20.100.6025 的顯示驅動都會讓我的premere pro cc 2018顯示綠畫面
我只能用回23.20.16.4901才顯示正常,請問何解?
最後想問Intel有沒有舊Nuc6i7kyk 付費更換升級Nuc8i7hvk的計畫阿...
我用這台2年了問題一直很多...真的不像旗艦該有的表現
不過Intel售後服務一直很好是我選用Intel的主要原因
目前等待問題被解決
Community Manager
Hello 咩爸,
I understand that you are having temperature problems with the unit and you would also like to check if there is a way to upgrade from the NUC6i7KYK to the NUC8i7HVK.
Regarding this, I would like to first suggest you to run a processor diagnostic to make sure that there is no problem with the processor itself. You can download the software for free from the link below:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool Intel ® Processor Diagnostic Tool.
When you are done with the diagnostic, please attach the results to this thread. Also, regarding your second question, we do not have a way to change your NUC for one of the new ones, we do not have that kind of pay-to-upgrade option. I apologize for any inconvenience.
David V
Community Manager
Hello 咩爸,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
CChen35
確實機器有問題,後來申請維修支援了,感謝
Community Manager
Hello 咩爸,
Thank you for your response.
I will then proceed to close this request for now. If you need any more assistance do not hesitate to reply.
David V
