Hi to all! Because it is the first time that i have to make such changes to BIOS, and i too have thermal issues, could someone please provide an analytical guide with all the changes that have to be done?
Firstly before doing anything should i keep Turbo Boost enabled and run Prime95 & Furmark for correcting thermal behavior and then apply any changes to the BIOS?
Then i just keep enabled turbo boost and apply -150vm in vcore or there are any other changes that have to be done?
After all that re-run Prime95 & Furmark?
Thanking you in advance!!
Just for clarity, when you say "I too have thermal issues" can you describe the system behavior that is leading you to that conclusion?
I just bought the unit and it's easily reaches 100 celcius in matter of seconds after boot with only running HWinfo!
When I say "I too have thermal issues" I'm reffering to the following thread
And I take it you have done the thermal conditioning of the TIM by running prime95 and furmark at the same time for burn-in of the TIM? If your CPU immediately hits 100C, undervolting is not going to do much for you.
No I haven't done the burn in test yet that's why I'm asking!This is what I should first.. right?
Thank you!I will do the test and then I will update here!
While you are waiting for it to complete, I suggest that you read this article: Plundervolt! A new Intel Processor ‘undervolting’ Vulnerability
