Intel® NUCs
12330 Discussions
Nuc8i7hvk Rgb Led 线损坏,如何获得它或者购买哪种型号的线替换
DevChen
David_G_Intel
Hello @DevChen
Thank you for posting on the Intel️® communities. Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate. There is no cable replacement or model we can provide, if the NUC is still under warranty, you can contact local Intel Customer Support to check if a NUC replacement is provided. Here are pages where you can lookup contact information, including local/country phone numbers, by geography:
You can use the online forms service or email, but I actually recommend calling them directly. The above links provide local or toll-free numbers in most countries and support most local languages. You could also use the chat service but understand that this service is offered in English only and is subject to the normal (9:00-5:00 M-F) office hours in the Pacific (UTC-8) time zone.
David G
