Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
OS crash with 16Gb of RAM
I've finally purchased a 16Gb Kit from Crucial with 2x8Gb for my NUC5i5RYH http://www.crucial.com/usa/en/nuc5i5ryh/CT6997365 http://www.crucial.com/usa/en/nuc5i5ryh/CT6997365
When both sticks are in, the OS crashes during boot time: Black screen, no response, not even CTRL+ALT+DEL, hard reboot needed.
- Trying to reinstall any OS, it crashes half way (LinuxMint, Windows Server 2012)
- Sometimes, Ubuntu server (no GUI) would install but have the same crash at random times.
- It works fine with 8Gb, with either stick of RAM in either slot, which is frustrating.
- The 16GB are recognised in the BIOS
- BIOS is updated to the latest version
- I've been trying to get some logs by installing an OS with 8Gb installed and then adding the other 8Gb stick but the crash is instant and I haven't found any interesting logs so far.
I work in IT support so I should have been able to figure it out but I suspect a hardware fault with the NUC.
Is there anything else I should test to make sure either way?
Highlighted
Super User Retired Employee
The problem is a fault in a DIMM, a fault in the board (or DIMM socket) or an incompatibility between the two DIMMs (I *have* seen this before).
Replacing the pair of DIMMs is the easier thing to try first, so I suggest you do that. If the problem repeats, then you can go through the RMA of the base unit.
Hope this helps,
Highlighted
Thanks Scott,
That was my assessment too but I I think it's the board.
I tried a pair of G-Skill F3-1600C11D-16GRSL in the past and had the same result, so it's very likely that the board has an issue.
I'll RMA it and post my results back.
Highlighted
Let us know how it goes...
Highlighted
It was replaced by intel.
One week turnaround from pickup to delivery.
It's being installed as we speak with no crash and 16Gb RAM.
I'm happy now!
