Symptom 1: After booting NUC from shut down condition, I access it using VNC. Response time from the NUC (asking for password) is noticeably slower than from any of my much older/slower/obsolete machines.. Symptom 2: Log shows failure to mount a NFS drive due to the LAN not being ready.
New NUCi5BEH, m.2 nvme SSD, 16GB ram.
Lan response performance compared to, and much worse than two other computers with lower specs, running the identical software.
HP 6300 Core Duo, 2GB ram,
Lenovo m92p, old i5 with 8 GB ram.
Any ideas?
Hello AnalogBill,
Thank you for submitting your question on this Intel® Community.
We would like to obtain more information about your system configuration. Please generate a system report with the Intel® System Support Utility (Intel® SSU) on your Intel® NUC and attach it to this thread.
Wanner G.
A Contingent Worker at Intel
Hello AnalogBill,
Thank you for the update.
As soon as you can, please let us know the outcome of these troubleshooting steps.
Wanner G.
I completely wiped the SSDs in my NUC and my Lenovo m92p test machine. Reinstalled OS, configured vnc servers and NFS mount points in both. The two machines are configured identically now, other than the hardware/firmware.
I've attached the scan file from the NUC for your review.
I'm going to run the SSU scan on my test machine next, and look for differences.
Since switching the NUC to UEFI boot, the problem of NFS mount failure is resolved, and the problem of slow response to my vnc client, is improved, however, the test machine continues to respond to the vnc client much faster.
Wondering if the NUC firmware has a network power saving mode that I need to change....haven't found anything yet.
Hello AnalogBill,
Thank you for your response.
Wanner G.
Hello AnalogBill,
If you need further assistance, please let us know. We will be glad to assist you.
Wanner G.
Hello AnalogBill,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Wanner G.
Hello AnalogBill,
It seems that the files were not attached to the thread. Try to use the clipboard icon when writing your answer to attach the files.
Also, could you please include the the version of VNC that you are using?
Is the NFS drive set to auto log-on on when you start the system?
Wanner G.
Ubuntu uses the x11vnc-server, and I have had no more VNC problems since I switched the NUC to UEFI boot,. I generally use a RealVNC client from a Windows 10 Pro box. and sometimes use an UltraVNC client on a Windows 10 pro laptop. Anyway, VNC is no longer a problem.
When Ubuntu boots up, it automatically mounts any drives. In my NUC I have the m.2 nvme SSD as a boot drive, and a Seagate 2.5" drive for data. Since the Seagate is internal, it mounts immediately. The problem is my NAS automount fails, and as I read the syslog, it appears that the NUC's nic is changing state while the NAS is trying to mount, causing it to fail. As soon as the NUC has booted into my OS, I can manually mount the NAS instantly. In the logfile, my NAS is identified as "DS1515".Several lines in the syslog, before and after the DS1515 mount failure, indicate to me that the network is unavailable when the mount is trying to happen.
I'm going to try the attachments again.
Hello AnalogBill,
We will look into this issue and try to provide an update as soon as possible.
Wanner G.
Hi AnalogBill,
I work with Wanner and we have been chatting about this case, we both believe that the NFS not automounting at boot is not related to any misconfiguration in BIOS or setup related to the LAN controller.
We think this is more of an Ubuntu* configuration issue and we found the documentation that addresses it, please see the following URL: https://help.ubuntu.com/community/Autofs
I would also recommend that you reach out to Ubuntu forums if you have questions since we provide very limited support for Linux* configuration related questions.
I hope this helps.
Ronny G
