Community
cancel
Showing results for
Search instead for
Did you mean:
POlen
Optane memory can not be detected by windows 10
I bought an Intel NUC7i5BNB like a 3 months which came with an Optane memory, I install and all worked fine. Two days as I was installing some windows and intel updates it rebooted with "A bootable device has not been detected'' I went to the BIOs and changed to RAID and it booted after repairing the windows. Now I can not detect the Optane on the windows at all. its not on device manager
On the Bios when I remove the Optane Memory Card I see the SATA Mode changing from 'Intel® RST and System Acceleration with Intel® Optane™ Technology' to RAID
the Optane Software shows me
My INET BIOS has nowhere to reconfigure Rapid Storage
Please Help
Community Manager
Hello olendo@gmail.com,
I understand that you Intel ® Optane Memory is no longer being recognized.
Regarding this, To better assist you with your request, I will need to check some information about your computer. Please follow these steps:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
Once we have this, I will review the report and attempt to find the problem and/or provide you with different suggestions to fix the issue.
David V
Community Manager
I am following up with your case and see that we have not heard back from you.
I would like you to please provide me with the information I requested above.
If you need more assistance do not hesitate to reply.
David V
ZSari
The same thing happened to me. I reinstalled win10, but optane still not recognised. Solution was the following
https://www.intel.com/content/www/us/en/support/articles/000026764/mini-pcs/intel-nuc-boards.html Intel® Optane™ Memory cannot be seen in the BIOS and Device manager...
Also there was a challenge to reinstall win10, problem with GPT ...
Now everything works fine, except I can't recover my image files from before crash.
Community Manager
Hello Tomagino,
Thank you for your response.
We appreciate your input and hope that other community peers who have the same problems find this to fix the issue.
David V
Community Manager
Were you able to follow Tomagino's suggestion?
David V
