Dear Intel Community,
I have a HP Envy 750-279na Desktop (Product Number N9C10EA#ABU) with a 6th generation Intel Core i7-6700 3.40GHz processor, bought in late 2106.
I am thinking of trying some HD video processing which will run the machine at near full power for up to an hour. Hence, I am concerned about overheat protection – particularly for the processor.
In reading the Intel datasheet for the processor (“desktop-6th-gen-core-family-datasheet-vol-1 Rev 8 Aug 2018”) I was pleasantly surprised to read the “Thermal Management” chapter – it seems to say (in summary):
“The maximum processor temperature should not exceed 80 Celsius and that various functions / process built into the processor will automatically cut in to prevent the processor overheating and being damaged.”
I am old and past it – also, I trained as a Theoretical Physicist rather than an Electronics Design Engineer – so please would one of the bright young intel experts out there let me know if the above is correct?
I would also appreciate being told if there are any caveats on the above – e.g. keep the processor fan and heat dissipation fins clean of dust.
With Best Regards … O&PI
2106 is in the future...
Doc
I am old and past it - and have two fingers bandaged - so I am allowed one typo. Yes 2106 =>2016
CBark3, Thank you for posting in the Intel® Communities Support.
In reference to your question, yes that is correct, the Intel® Processors have a feature that when the unit gets overheated the computer will go off automatically to prevent any damage to the unit itself and to the rest of the components in the system.
For the Intel® Core™ i7-6700 Processor specifically, the T-case temperature is 71°C, so any temperature value below that measure it is considered normal and expected, as long as the Intel® Processor does not reach a higher temperature than 71°C, the unit should be working fine:
Regarding the caveats, in this case, HP customized their PC, they provided all the necessary components, features and BIOS settings for the Intel® Processor to work properly with their platform.
Before doing any changes, what we recommend is to get in contact directly with them so they can provide further suggestions to avoid for the unit to get overheated from HD video processing:
Alberto R.
A Contingent Worker at Intel
CBark3, We will be more than glad to further assist you.
If you have any further questions about this topic, please post them on the thread so all the peers in the Intel® community will be able to see the results and all details about this matter.
Alberto R.
CBark3, You are very welcome, thank you for posting those details in the thread.
In reference to your questions:
-Am I right in assuming that desktop PC components generally most at risk of overheating are the Processor, the GPU and the RAM chips?
Yes, actually, if the PC gets overheated, all the components are at risk, including the motherboard itself, but those will be components most at risk.
-I am not sure if these temperatures refer to the case temperature or to that of the four cores, so perhaps you could clarify / comment?
The manufacturer of the PC has the option to customized everything on their products, based on the parts installed, the airflow, the case, the fans and all the components installed by them the PC will have different behaviors about overheating and temperatures.
So, if they said that those are the temperatures values that this specific PC will reach, then that information is correct, they are the proper ones to confirm those details.
-The maximum safe temperature for R7 360 under high continuous load is around 95C.
It is recommended not to run the GPU at 80-85C for long time as it might reduce the longevity.
Same, scenario, AMD is the manufacturer of the AMD Radeon (TM) R7 360 Series graphics card, so if HP installed that component in their PC, then they customized everything in there to comply with those conditions.
-They said: Normal Operating Temperature Range is 0-85 Celsius, with an Extended Temperature Range (subject to caveat) of 85-95 Celsius
For this question is the same situation, Hynix is the manufacturer of the memory RAM and they are the only ones that will be able to confirm those details. Just like with the video card, if HP installed that component in their PC, then they customized everything in there to comply with those conditions.
-Am I correct to assume that safe processor core temperatures are up to 80 Celsius (or perhaps higher)?
According to the specifications of the Intel® Core™ i7-6700 Processor specifically, the T-case temperature is 71°C, so the temperature should not go higher than that value for the unit to work properly. Once again, the same thing, since HP customized the PC they will install the proper components for the PC to work without any problems.
https://ark.intel.com/content/www/us/en/ark/products/88196/intel-core-i7-6700-processor-8m-cache-up-...
Alberto R.
Hi CBark3, Thank you very much for your response.
Yes, you are correct, the T-case temperature is the one that measures the temperature of cooper IHS (Integrated Heat Spreader).
DTS is the temperature reported by the many digital thermal sensors within a CPU. Yes, it is the temperature of all the cores, and yes it might be higher than 71°C, as stated by HP it could be 60-85 °C but it varies depending on the Intel® Processor model.
Tjmax: Fixed limit that any of the DTS can reach, after which frequency throttling will occur. All 3 temperatures are an indicator of CPU die temperature. It is the overall temperature reported by both the T-case and DTS that will activate the THERMTRIP# signal to shut the system down automatically to avoid any damage of the internal components.
You are correct about the DTS and Digital Thermal Sensor-based fan speed control (TFAN).
You are also right about the THERMTRIP# signal information. The 130 °C value may vary from one Intel® Procesor to the other since not all of the Intel® Processors are the same or have the same temperature limit, some of them might activate the signal with a temperature value lower than 130 °C.
In the following link, you will find further details about the Intel® Processors temperatures:
https://www.intel.com/content/www/us/en/support/articles/000005597/processors.html
Alberto R.
Hello CBark3, You are very welcome, thank you very much for sharing your feedback.
-Yes, that is correct, it is the equivalent of the (Integrated Heat Spreader) that conduct heat away from the processor.
-In reference to your second inquiry, the thing is that the Intel® processor has different layers, there is the temperature between junction (ide) and IHS, there is also the temperature between IHS and the heat-sink and also the temperature between the heat-sink and ambient. Those 3 temperatures are different, but they are measured as an overall temperature that will be the Tjmax, and no, it is not safe if that temperature value goes above 100°C.
Perfect, it is good to have the SpeedFan set to provide warnings if processor core temperatures exceed 70°C.
Thank you for posting the questions in the Intel® Communities support, those were very interesting questions and we are sure the details of this thread will be very helpful for all the peers viewing this conversation.
And yes, of course, you can always use the Intel® Processor Diagnostic Tool to test the Intel® Processor, it does an overall test on the unit to make sure it is working fine:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Also, for temperature verification purposes, you can always use the Intel® Extreme Tuning Utility, this tool will allow you to monitor the temperature of the Intel® Processor and also to run a stress test on the unit:
Alberto R.
Hi CBark3, Thank you for providing those details.
Not sure what you mean with the recommended HP software test packages, the applications that we advise to use are either the Intel® Processor Diagnostics Tool or the Intel® Extreme Tuning Utility. Additionally, about the dust clean-out, there are different reports from many peers stating that if you open the case of the HP PC, that will avoid the warranty on it, so we do not recommend to do that.
In regard to the SpeedFan and Norton 360 Full System Scan, those are 3rd party tools, so we cannot comment on the results, we only rely on the Intel® applications mentioned previously.
Same thing with the Microsoft updates, if you need to confirm some details about how it works or the features it has, the best thing to do will be to get in contact with Microsoft directly for them to confirm that information:
https://support.microsoft.com/en-us
You can also get in contact directly with HP for them to provide additional recommendations to avoid for the computer to get overheated.
Alberto R.
