intel nuc8i3bnh Overheating fan problems. Requests instructions for disassembling the fan. If possible. I searched all over the internet and did not find this model.
Thanks to the respondents.
My understanding is that it's not that easy to take the fan apart. If you have overheating you may want to check and clean the fan vents to make sure they are open. Then you could go into the bios and change the fan settings to cool. It may not work, but I would definitely try these things first ... much easier!
Thanks for your response. The aisles are clean, the only reason for this heating is the fan. There are instructions for other models and not the model I registered. I have the nuc7i5 and I had no problem getting to the fan and cleaning it.
