Intel® NUCs
Assistance in Intel® NUC products
12986 Discussions
Phantom Canyon NUC11PHKi7C Display Output Issue
Shaunn
I am using it with a Dell S2721DGF via USB - C (NUC side) > Displayport cable.
1440p 144hz and 165hz only works with 6bit color. The cable i am using worked with a previous laptop I owned at 1440p 165hz and 8bit color. With the nuc, only 1440p 120hz does 8bit color fine though. Any idea how i could get 1440p 165hz to work at 8 bit color?
David_G_Intel
Hello Shaunn
Thank you for posting on the Intel️® communities.
Please share with us the following information:
  • Intel® System Support Utility (Intel® SSU) report
  • Intel® Graphics Command Center report
    • Open the application
    • "Support" > "System Diagnostic" > "Generate Report
David G
Intel Customer Support Technician
DeividA_Intel
Hello Shaunn,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
David_G_Intel
Hello Shaunn
David G.
