Community
cancel
Showing results for
Search instead for
Did you mean:
CFran9
Plans for more than 3 USB ports??
Is there any plans for a NUC that can have more than 3 USB devices plugged in? We wish to use them in retail and after the keyboard and mouse are plugged in there isn't any room to plug in Receipt Printer/Barcode Scanner/Label Printer/Electronic Payment Handset.
We have thought of a powered USB hub (or two) but from experience they are unreliable.
Tags (2)
LHill_Intel
Hello ClintNZ,
In the September/October time frame, there will be a new NUC version that has two USB ports on the front and two on the back. For now, there are other options:
- if you have installed one of the Intel WiFi cards that supports bluetooth, use that to pair up with bluetooth keyboard and mouse instead, freeing up two ports
- use a 'universal' USB dongle that supports mouse and keyboard wirelessly, freeing up a port
- use a hub; we have a customer report of one that works at http://support.intel.com/support/motherboards/desktop/sb/CS-033763.htm http://support.intel.com/support/motherboards/desktop/sb/CS-033763.htm
Lois H.
Intel
