Hello
Is it possible to add a second MvMe M.2 SSH in the NUC10i7FNH
Specs speak about RAID 0 and 1 , but is it only on the SATA-interface (2 are avaiable if I dont make a mistake),
or between the MvMe M.2 and a SATA SSD (but then performance will drop I'm afraid)
or is there a possibility to add a second MvMe M.2 ?
Thanks for your help.
Best regards
RAID is only supported using one interface, NVMe or SATA, not both. AFAIK, you cannot mix interfaces. In the FN NUCs, you have a single M.2 Type M connector for a (max) 2280 SSD. Your only option for RAID is thus via SATA, namely using a M.2 SATA SSD and a 2.5" SATA SSD/HDD. If you use the M.2 Type M connector for a NVMe SSD, then you cannot use RAID.
I'm throwing a tantrum here. Speaking. But, as far as I noticed both the nvme's can just operate at the sata interface. Just like always with a limited backwards compatibility.
Take your tantrum elsewhere; it has nothing to do with this conversation. The FN NUCs only have a single M.2 Type M connector, so there's no 'both'.
