Community
cancel
Showing results for
Search instead for
Did you mean:
Power Plans Missing in NUC10i7FNH - AGAIN!
Early this year I had the problem, that I wanted to tweak power plans on the NUC within Win 10 and did not find other then the one listed below (only "balanced") .
C:\Users\PrimeMover>powercfg -l
Bestehende Energieschemen (* Aktiv)-----------------------------------
GUID des Energieschemas: 381b4222-f694-41f0-9685-ff5bb260df2e (Ausbalanciert) *
I was able to show all power plans (e.g. "high performance power plan") by set   HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power and set CsEnabled zo zero (0) with regedit...you find this on the Internet...
 NOW..
after several Intel/WIN 10  updates I noticed that everything was set back, means only the balance power plan is available AND in the registry CsEnabled is GONE...
So AGAIN...
Anybody who knows how to show ALL power plans under WIn10 and on a NUC 10?
Thx in advance, Martin
Super User Retired Employee
Did you try re-creating this registry entry? If they haven't disabled its use, this should work.
Hi and thanks for your comment...
Just found a hint that beloved MS retired the CsEnabled registry entry (go to the bottom here:https://answers.microsoft.com/en-us/windows/forum/all/csenabled-not-available/cb49f247-090a-40cb-905...)...
...for whatever reason.
Leaves me again with the problem, how to activate on a Intel NUC 10 the high performance power plans...
Anybody having any idea?
Hello MKemp4,
Thank you for posting on the Intel® communities.
For this specific problem, I will highly recommend you to check with Microsoft* for a possible solution as this seems to be a Windows limitation.
https://support.microsoft.com/en-us
Sebastian M
Intel Customer Support Technician
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
New Contributor III
Have you tried disabling Modern Standby in the BIOS? This may restore the power plans to Windows. Only thing is this may mess up your Windows install so make sure you have a backup before changing this setting. This will restore S3-5 Power Modes back to the NUC.
