Intel® NUCs
Assistance in Intel® NUC products
12961 Discussions
Power Supply (higher wattage needed PCIe video card)
SterlingMark
Hi - I have the NUC9i7QNX and am installing video card.
After seating the card and organizing cables.
On power on, my monitor goes active (blue) then no signal then orange then off.
I'm wonding if the power supply needs to be reviewed, or video card changed.
Are there any options for higher wattage power supply, or is that not the issue....
In another system card (with power plugged in top) worked fine.
Not so much in the NUC... perhaps I'm not giving it time for the Video Card to post.
Wondering if this ASUS RTX 3050 requires more power than is available, on the line?
It's using the 8pin aux power cord.  OC edition 8GB PCIe express support 4.0
I'll include a shot of the exact model info
If there are any larger power suppliers for these NUC's where can I find them?
485 W currently in it, I believe.
Is there a listing of prefered/tested cards for these 2022 NUC's QNX.
Thanks-
Mark
SterlingMark
Oops, forgot to attach file.  See attached pic of the ASUS card info
Steven_Intel
Hello SterlingMark,
In order to better assist you, please provide the following information:
  • To confirm, is the NUC turning on and then off when you try to use with the dedicated graphics card connected?
  • What cable are you using to connect the NUC to the monitor? Have you tried a different one?
Here is a list of compatible graphics card for this NUC model (https://compatibleproducts.intel.com/ProductDetails?activeModule=Intel%C2%AE%20NUC&prdName=NUC9i7QNX). Even though the graphics card it not listed, it should work based on the specifications.
Steven G.
Steven_Intel
Steven G.
SterlingMark
Sorry for late reply. Thank you for the great compatibility listing. I was able to install and use the 3050 without issue. The i7QNX has 5Tb and runs perfectly.
Mark
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
