Hello I have an arcade cabinet inside there is an Intel Nuc C8i5bnh.
How to move the Nuc power switch button to be able to install an external button on the arcade terminal.
Currently I have to open the arcade terminal to turn off my Intel Nuc.
Do you have a solution to deport the on / off button of the Intel Nuc thank you in advance
There is no NUC8i5BNH, rather there is NUC8i5BEH. You can connect momentary switch between pins 6-8 on Front Panel Header. Refer to para. 2.2.4.4.4 in Technical Product Specification
In case that you have NUC7i5BNH, do this same as described in para.2.2.4.4.4 in Technical Product Specification.
Leon
- Tags:
- By plugging an external connector into pin number 6 and 8 on the front panel Header
- By plugging an external connector into pin number 6 and 8 on the front panel I hope I won't bypass my Intel Nuc
- I hope that it will work
- I hope that it will work !
- I will not bypass my Intel Nuc
- Thank you very much for your help for the Nuc8i5BEH it was a typo!
Leon
- Tags:
