Intel® NUCs
12110 Discussions
PowerDVD can't play HDR movies on Intel® NUC Kit NUC8i7HVK
UTran
I have Windows 10 64 bit installed on my Intel Nuc NUC8i7HVK. All drivers were downloaded from this site https://downloadcenter.intel.com/product/126143/Intel-NUC-Kit-NUC8i7HVK Downloads for Intel® NUC Kit NUC8i7HVK and installed. NUC is connected to Yamaha A3070 receiver and then to Sony TV Oled A1. Belkin Ultra High Speed 4K HDMI Cables used for both connections.
PowerDVD 18 can't play HDR videos, saying that my TV can't play HDR.
Please help me with this issue. Thanks.
n_scott_pearson
Super User Retired Employee
Does it work if you direct connect the NUC to the TV?
UTran
I tried, but It made no difference. It says "You computer or display device does not support HDR. Do you want to play the video with SDR instead?"
I run DxDiag. Attached is the report.
BHjal
Sorry to give this answer, but NUC8I7HVK is not supporting Blu-ray UltraHD /HDR!
The limitation is built into the HW, HDMI interface must be connected to a Intel Graphic circuit to this format to work with Blu-ray UltraHD/HDR .
One of the demanding requirements on the HW to get Blu-Ray Ultra HD to work.
In NUC8I7HVK HDMI interface is connected to the AMD Graphics circuits., see Technical Specification for NUC.
Neither you can play 4K/HDR on Youtube as the AMD Graphics does not support the VP9 Codec. The maximum is 1080P.
BR/Björn
UTran
It's really disappointing. Thanks , anyway.
UTran
Can we use an eGPU to solve this issue? If yes, what do you recommend?
BHjal
What is your HW setup?
What is the media on, a file or a disk?
/Bjorn
UTran
I'm using Intel Nuc NUC8i7HVK. NUC is connected to Yamaha A3070 receiver and then to Sony TV Oled A1. Belkin Ultra High Speed 4K HDMI Cables used for both connections. The media is on file.
BHjal
No, as I understand the display must be connected to a motherboard with Intel Graphics 630 or better.
If you run Cyberlink Ultra HD Advisor you can find information how to build a PC that supports UltraHD Blu-Ray HDR.
BR/Björn
UTran
Thanks for your help.
Btw, is there any other Intel nuc that can do this?
BHjal
NUC8I3BE/NUC8I5BE/NUC8I7BE seems to meet the requirement on paper.
https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/NUC8i3BE_NUC8i5BE_NUC8i7BE_TechPr... https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/NUC8i3BE_NUC8i5BE_NUC8i7BE_TechPr...
The only missing function is SGX support in BIOS. But I guess it's there?
You better verify with Intel that it support all requirements.
BR/Björn
Community Manager
Hello all,
Regarding the Intel® Software Guard Extensions for Intel® NUC, it is required:
-If SGX security is enabled in BIOS.
-To play UHD Bluray content.
https://downloadcenter.intel.com/download/27118/NUCs-Intel-Software-Guard-Extensions-Intel-SGX-for-I... Intel® Software Guard Extensions (Intel® SGX) for Intel® NUC (NUC8I3BE / NUC8I5BE / NUC8I7BE)
I hope you find this information helpful.
Wanner G.
UTran
I enabled SGX in Bios, and then tried to install https://nam03.safelinks.protection.outlook.com/?url=https://communities.intel.com/external-link.jspa... Intel® Software Guard Extensions, but failed. It says
"Fatal installation blocking issues are detected.
AESM has already installed by INF on this platform. Install will cancel".
BHjal
Which NUC are you using?
/Bjorn
UTran
BHjal
I have manage to activate SGX on my NUC8I7HVK, but it does not help in getting UHD Blu-ray support as Advanced Protected Audio/Video Path is not support in Vega Graphic.
This HW platform will never support UHD Blu-ray.
If you want anyway SGX on your system I think the Intel people should be able to help you.
By the way, which country are you from?
BR/Bjorn
BHjal
I found a good document on the subject HDR on Intel Graphics
https://www.intel.com/content/dam/support/us/en/documents/graphics/HDR_Intel_Graphics_TechWhitePaper... https://www.intel.com/content/dam/support/us/en/documents/graphics/HDR_Intel_Graphics_TechWhitePaper...
The table at the end of the document gives a good overview of the requirements depending on the HDR source.
BR/Björn
UTran
Thanks very much for your help.
I'm from Vietnam
BHjal
I have found some more information about this subject on Intel Site.
A link to a report from about Compatibility information NUC8I7BE. It show that it must support UHD Blu-ray as there is one UHD 4K Drive listed
http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel®%20NUC&productType=Kits&productName=Intel®%20NUC%20Kit%20NUC8i7BEH http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel®%20NUC&productType=Kits&productName=Intel®%20NUC%20Kit%20NUC8i7BEH
Tips for playing 4K or HDR material on Intel NUC
https://www.intel.com/content/www/us/en/support/articles/000029357/mini-pcs.html?wapkw=nuc8i7be https://www.intel.com/content/www/us/en/support/articles/000029357/mini-pcs.html?wapkw=nuc8i7be
BR/Björn
