Community
cancel
Showing results for
Search instead for
Did you mean:
IPoto
Problem with NUC 7i7BNK
Problem with NUC 7i7BNK, i have the NUC connected via HDMI 2.0 to 4k Philips 40inch monitor. The problem is when i dont use it for a while and it goes to sleep or if i RDP on it or if it is up all night and then when i work with it in the morning, i must every time hard reset or manualy shut down it, to get the picture back. I dont know it looks like that the nuc doesnt give the monitor thje command to power up. is It here some methode to change this? Its really bothering me because i must oto do this everyday or at least on 5-6hourrs if i dont use it?
Community Manager
Hello, InfoT2014. Thank you very much for contacting the Intel Communities Team. I will be more than happy to assist you.
In order for me to assist you better, please provide me with a DxDiag* report. Please follow these steps to generate it:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it to your desktop).
4. Attach the .txt file that was generated. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Additionally, please share with me the model of the monitor you are currently using. Also, is the NUC connected directly to a wall plug? And, are you using the power adaptor that came with the NUC?
Antony S.
Community Manager
Antony S.
IPoto
Hello here is the result of DXdiag.
The monitor is model PHILIPS
Brilliance 4K Ultra HD LCD display with MultiView
40" (101.6 cm), 4K UHD (3840 x 2160) BDM4037UW/00
The NUC is connected to power circut over the extender of power and it is not connected to the wall plug. Yes we use power adapter that came with NUC.
Community Manager
Thank you very much for the information provided, InfoT2014.
By checking the attachment, I can see that your BIOS (installed 0057) and Graphics Drivers (installed 4944) are outdated. Let's update that by following these steps:
  1. For your to update the drivers please click https://downloadmirror.intel.com/27680/a08/win64_24.20.100.6025.zip here to download the latest version of them (6025) and in order to install them please follow the steps provided in the following link: https://www.intel.com/content/www/us/en/support/articles/000005629/graphics-drivers.html https://www.intel.com/content/www/us/en/support/articles/000005629/graphics-drivers.html
  2. For the BIOS update, click https://downloadcenter.intel.com/downloads/eula/27734/BIOS-Update-BNKBL357-86A-?httpDown=https://dow... here to download the .bio file of the 0063 version and follow the steps of this guide: https://www.intel.com/content/www/us/en/support/articles/000005850/mini-pcs.html https://www.intel.com/content/www/us/en/support/articles/000005850/mini-pcs.html
Please share with us the results.
Antony S.
Community Manager
Hello, InfoT2014.
I would like to know if you still need assistance. If so, please do not hesitate to reply to this thread.
Antony S.
IPoto
Hello, sorry i didnt saw the answer will try today.
Community Manager
Hello, InfoT2014.
I would like to double check if you were able to perform the troubleshooting steps that I attached to the post above and the results.
Antony S.
