Intel® NUCs
Problema BIOS
MMale6
Hi, there.
The problem I have with my NUC6CAYH is that the BIOS takes 4 minutes to appear on the screen.
Some solution.
Thank you
n_scott_pearson
Super User Retired Employee
Please describe your system better. Provide full part numbers, not descriptions, wherever possible. What memory? What storage devices? What O/S(s) installed?
MMale6
Thank you for your answer.
Windows 10 pro 64bits - 4Gb RAM
SSD Hard Disk Drive
Monitor: tv philips 43" Resolution : 1280 x 720 (I have tried different resolutions and the problem persists)
n_scott_pearson
What part of "provide part numbers" didn't you understand?
MMale6
I didn't get any part of it because the translation the machine translator gives me doesn't make any sense to me.
Could you please rephrase the phrase "provide part numbers"
n_scott_pearson
We need to know the part number for the memory SODIMM(s) that you have installed. For example, my NUC6CAYS has an Crucial 8GB DDR3L SODIMM installed whose part number is "CT102464BF160B.M16FN".
..S
MMale6
Esta es la memoria:
Kingston KVR16LS11/4 - Memoria RAM de 4GB (DDR3L Non-ECC 1600 MHz, FBGA SODIMM 204-pin, 1.35 V CL11)
n_scott_pearson
Thank you, that is what I needed to know -- and you are absolutely right; Google does a *horrible* job of translating Italian to English and English to Italian.
So, this tells me that you have compatible memory (incompatible memory is one of the things that might cause a delay like this). We can look at the next possibility.
Next, please tell me what version of the BIOS you have installed. The latest BIOS is version 50 (AY0050.BIO, AYAPLCEL.86A.0050.2018.0521.1533). If you do not have this version installed, you should upgrade to it now. Instructions for doing so can be found here: http://www.intel.com/content/www/us/en/support/boards-and-kits/000005636.html Intel NUC BIOS Update Instructions. You can download the BIOS from here: https://downloadcenter.intel.com/download/27837/NUCs-BIOS-Update-AYAPLCEL-86A-?product=95078 Download BIOS Update [AYAPLCEL.86A].
MMale6
Hi, there.
The bios is already updated, now it is the last version, but unfortunately everything is still the same.
n_scott_pearson
Ok, the next thing to try is a 2-step process: (1) Clear CMOS (see http://www.intel.com/content/www/us/en/support/boards-and-kits/000005805.html Intel NUC Clearing CMOS for more information) and (2) Reinstall the latest BIOS release, but this time do so using the (highly recommended: jumper-based) BIOS Recovery process (see http://www.intel.com/content/www/us/en/support/boards-and-kits/000005532.html?wapkw=bios+recovery Intel NUC BIOS Recovery Update Instructions for more information).
Some additional notes on the BIOS Recovery process:
  1. The use of a USB 2.0 flash disk is recommended. There are compatibility issues with some USB 3.0 flash disks.
  2. Reformat your USB flash disk, on a Windows-based PC (NOT Linux or MACOS!), using the FAT32 file system and with the Quick Format option disabled.
  3. Place only file AY0050.BIO onto the USB flash disk. Specifically, there should be no other .BIO files on this flash disk.
Hope this helps,
