Community
cancel
Showing results for
Search instead for
Did you mean:
CSinc1
Problems after installing Optane drivers
Jump to solution
Hi
I have just bought an NUC 7i5BNHX1. I installed Windows 10 and updated all drivers and the BIOS on the Intel Download Centre, followed by a reboot. So far, so good, all was working perfectly. I then downloaded the Intel Optane Memory driver (I think it was v15.8) ZIP file and installed it as an Administrator. It seemed to install OK but I did not see the "Would you like to finish the setup process by enabling Intel Optane memory?" pop-up window, as described in the instruction sheet that came with the computer. Now, Windows appears to boot OK, but I cannot log on. Furthermore, Windows seems to have lost the network connection (neither Ethernet nor Wi-Fi work). The other odd thing is that the blue ring light is now permanently on, even though I disabled the HDD activity LED in the BIOS.
Any advice on how I can get the computer working again?
Thank you.
Accepted Solutions
CSinc1
OK I have resolved this by reinstalling Windows. The ring LED light being on was a BIOS setting that I don't recall changing, but must have.
CSinc1
