I'm a bit stuck and could use your help/suggestions. I got a new NUC7CJYH with Win10 installed on it, but want to run it as a headless Ubuntu server. I followed the instructions here: https://ubuntu.com/download/intel-nuc Which all worked alright.
I generated the SSH key on WSL2 on my windows laptop, saved it to my Ubuntu profile, and so far so good, ran the install, and also worked fine.
Then I get the screen on the NUC telling me what I should type to SSH into the machine, which is where the problem comes in. I am able to connect to the NUC, and it asks me for my password, so I am entering my Ubuntu SSO password, which it's not accepting, I even went as far as creating another Ubuntu SSO account and doing the same setup again, and the same thing. I also tried with the username/password that I used to generate the SSH key, and I keep on getting the following error :
ssh nuc_00101@192.168.0.251
The authenticity of host '192.168.0.251 (192.168.0.251)' can't be established.
ECDSA key fingerprint is SHA256:BsIlNy+QMHpeHNuX1yAcHGjCytWAxmdCfH5rtP8OXuw.
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Warning: Permanently added '192.168.0.251' (ECDSA) to the list of known hosts.
nuc_00101@192.168.0.251's password:
Permission denied, please try again.
nuc_0010173@192.168.0.251's password:
I have no idea where to go to from here, so any suggestions would be appreciated. I was thinking of maybe then just rebooting it again and telling it to install ubuntu-desktop (even though I will run it headless) but ideally, I'd like to get this fixed rather than potentially introducing more problems
Thanks!
@Lily6388 wrote:
I'm a bit stuck and could use your help/suggestions. I got a new NUC7CJYH with Win10 installed on it, but want to run it as a headless Ubuntu server. I followed the instructions here: https://ubuntu.com/download/intel-nuc/peryourhealth Which all worked alright.
ssh nuc_00101@192.168.0.251 The authenticity of host '192.168.0.251 (192.168.0.251)' can't be established. ECDSA key fingerprint is SHA256:BsIlNy+QMHpeHNuX1yAcHGjCytWAxmdCfH5rtP8OXuw. Are you sure you want to continue connecting (yes/no/[fingerprint])? yes Warning: Permanently added '192.168.0.251' (ECDSA) to the list of known hosts. nuc_00101@192.168.0.251's password: Permission denied, please try again. nuc_0010173@192.168.0.251's password: Permission denied, please try again.
Thanks!
Any update??
Hello Lily6388,
You must know that the Operating system you are running has not been validated to work in your unit. If you want to take a look at the list of the validated operating systems, you should refer to the following link:
https://compatibleproducts.intel.com/ProductDetails?prodSearch=True&searchTerm=NUC7CJYH#
However, if you want to stick to installing the operating system, I recommend contacting the Linux support team for further support.
Jean O.
Hello Lily6388,
I hope you are doing fine.
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
