Hi folks,
Since November, when it was released, the Support Assistant says that I should update to
My system is NUC12WSBi7 Version M46422-302, Win 11 Pro, if that matters.
Thank you.
Try downloading the package yourself (from here: https://www.intel.com/content/www/us/en/download/18649/741441/intel-wireless-bluetooth-for-windows-1...) and install it manually. Check what driver is present after doing the install and then again after doing a reboot(to see if Windows Update is interfering with it).
Did you hide it for only a short time (a week or a month) or did you hide it permanently?
BTW, to me, this appears to be a catalog error. @Monique_Intel/@Chris_V_Intel - is this the case or is it something else?
Thanks, Scott. I have tried hiding permanently, but haven't succeeded in getting it to stick. If this preference is being captured within the browser, it's probably *not* going to stick, for various reasons, on my box.
At any rate, I would in fact rather have the update than not, if it exists!
Hi Scott,
(This is my second reply, I am not sure if the site ate my previous reply or if you will see two, if so, sorry.)
That worked although it was a little strange. It required me to uninstall the previous version from Add/Remove Programs before it would install, which is something I wouldn't normally have to do when updating a driver?
Once that was done, I checked the Support Assistant page and let it attempt to do the upgrade. Sure enough it wanted to install .3 over .4, so it's definitely the database/aka "catalog link" that is amiss here. After I refreshed Support Assistant's information about my box, it says I am now up to date, yay.
Thank you for your help!
PS the page you gave me (https://www.intel.com/content/www/us/en/download/18649/741441/intel-wireless-bluetooth-for-windows-1...) was not the same manual download page I had used before. And it provided an executable, whereas the one I had found before by going through the info on the Assistant page (https://www.intel.com/content/www/us/en/download/757473/intel-wireless-bluetooth-driver-for-windows-...) provided a zip file.
