hello, I have a problem with my new purchased device.
short description of problems:
clean install of windows 10 pro x64 -1803 , no matter type of hdd ( ssd or standard ), different stick of ram , after windows installation finish I not install nuc drivers restarting nuk, windows start normally. After that I do shutdown from windows , nuc is not fully switch off, blue power indicator staying on and power button not working, I must switch off from power cord.
If I install nuc drivers , windows can't start normally - different BSOD. After 5-6 restarts windows start normally, after that windows run normally until next reboot or shutdow.
I think that's a hardware problem.
p.s. sorry for bad Englis.
Thank you very much for sharing your issue with the Intel Communities Team, bobidi. I will be more than glad to assist you.
Firstly, can you please share with me the model of the SSD/HDD and RAM modules that you have tested on your NUC? Additionally, what is the BIOS version installed on the unit? Furthermore, have you tried using another Windows 10* image?
Antony S.
Hello, bobidi.
I would like to know if you still need assistance. If so, please do not hesitate to reply to this thread.
Antony S.
