Intel® NUCs
Support for Intel® NUC products
12729 Discussions
Product Differences
TOTOTO
BXNUC9i7QNX   JAPAN model
BXNUC9i7QNX1   US model
Is there any difference in performance between these two products?
Can I use US models in Japan?
n_scott_pearson
Super User Retired Employee
The only difference is the power cord. If you can use the US cord, then you can use it as-is -- or, you can replace the cord. Your code without number at end comes with no power cord, so you'd be purchasing one regardless.
TOTOTO
TOTOTO
Thanks a lot
Except for the power cord issue, are you saying that other US models of the Intel NAC series can also be used in Japan?
n_scott_pearson
Yes. The power supply takes any AC voltage from 100V to 240V. You simply need cord for local outlets.
TOTOTO
